1 страниц (4 вхождений)
how to display minutes in a result? - Is there a smart way for display of minutes in a result? - Сообщения
#1 Опубликовано: 01.04.2018 15:40:58
Dear community,
Again I have another beginner question:
I wonder if there is a smarter way than mine to display "minutes" in a result. I did not manage to use the search function since search terms like "time" or "minute" or "angle" deliver too many results.
My problem is to show results of time and angular calculations in a user friendly way. Currently I do it by putting the values into a matrix (see example). But this is mathematically incorrect.
Does anybody have a smart solution for this ... e.g. a user defined unit?
Thanks in advance for every idea!
Best regards,
Ralf
Best regards,
Ralf
#2 Опубликовано: 01.04.2018 19:30:16
I don't know if my solution is smarter, but the display is closer to what you want. The seconds symbol should be " but that doesn't work.
DMS.sm (9 КиБ) скачан 85 раз(а).
sergio 02.04.2018 05:15:00
#3 Опубликовано: 01.04.2018 23:26:38
WroteThanks in advance for every idea!
Maybe you can set as you wish, getting inspired from Martin guidance.
Maths Convert [deg, min, sec].sm (4 КиБ) скачан 89 раз(а).
Новые сообщения
Нет новых сообщений
