ARRAY/MATRIX QUESTION
ARRAY/MATRIX QUESTION - LARGE VECTORS/MATRICES - Сообщения
#1 Опубликовано: 07.06.2023 18:50:57
RegRetired
RegRetired
8 сообщений из 130 понравились пользователям.
Is there an easy way to scroll through a very large matrix?
Thx
Reg Curry Loveland, CO
#2 Опубликовано: 08.06.2023 12:10:28
Is there an easy way to scroll through a very large matrix ?
Very easy as suggested.
Page8 Scroll Matrix.sm (3 МиБ) скачан 51 раз(а).
#3 Опубликовано: 08.06.2023 14:46:17
If you can't download attached documents,
can you attach your big matrix ?
Describe/explicit your demand.
#4 Опубликовано: 08.06.2023 17:58:05
Scroll matrix ... quick/quick/done
#5 Опубликовано: 08.06.2023 18:23:01
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Thx
Hi. I guess that the effort less way is putting the matrix into a Table region, and using the 8 three dots that appear at borders and edges for navigating in the matrix.
#6 Опубликовано: 08.06.2023 18:34:36
Answer is YES matrix ... NO w/o matrix.
That means, attach your large *.sm matrix.
#7 Опубликовано: 08.06.2023 20:03:03
RegRetired
RegRetired
I like the idea of tables; however, as far as I can tell, it will not do continuous scrolling. Maybe I am missing something.
Файл не найден.
Reg
Jean, I am having trouble understanding how to use your sm file.
#8 Опубликовано: 09.06.2023 07:53:23
Download this one, confirm you can open.
Simply a bit more descriptive, cross hair helper from Padding the region
Padding is what we use to zoom Fourier a gray or RGB image, up to zoom 2.
For larger zoom, I use IrfanView or WinGrab.
Cheers ... Jean. Take Care.
Image Matrix Scroll Region Copy.sm (3 МиБ) скачан 50 раз(а).
#9 Опубликовано: 09.06.2023 08:56:50
You are not missing anything.
There is no continuous scroll for table region.
