Multiple Binary Boolean Operators in if statement
Multiple Binary Boolean Operators in if statement - Add multiple binary Boolean "or" / "and" operators without force parenthesis - Сообщения
#1 Опубликовано: 06.05.2022 22:53:10
Larry Burns
Larry Burns
When I try to perform this if-or statement:
if a=1 ^ a=2 ^ a=3
x=4
else x =5
I end up with this due to forced parenthesis:
if ((a=1 ^ a=2) ^ a=3)
x=4
else x =5
Could we have capability for multiple binary operators without forced parenthesis enclosure?
#2 Опубликовано: 07.05.2022 00:27:03
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi. The short and honest answer is not. The long and tricky answer is that you can, but you must edit the .sm file and delete the lines with (
However, unless it's for some publishing purpose or something like that, I don't think it's convenient. Also, you can neither copy nor edit it without the parentheses reappearing.
and_tryck.sm (2 КиБ) скачан 72 раз(а).
#3 Опубликовано: 07.05.2022 08:59:32
Think in term of productive Bolean.
Critical.sm (30 КиБ) скачан 80 раз(а).
#4 Опубликовано: 09.05.2022 08:01:56
... lot more involved. Adapted from Frank Rioux MCD 11.
Fourier Quantum 2C Mask.sm (22 КиБ) скачан 66 раз(а).
#5 Опубликовано: 09.05.2022 08:37:41
You can always create some function to make it look like you are working with some set of numbers
sergio 09.05.2022 10:55:00, Alvaro Diaz Falconi 09.05.2022 11:19:00, Arie 09.05.2022 16:16:00
#6 Опубликовано: 09.05.2022 10:06:38
Tanks Davide ... coded/saved.
Take care ... Jean.
Maths Conditional Davide.sm (12 КиБ) скачан 73 раз(а).
sergio 09.05.2022 12:46:00
#7 Опубликовано: 09.05.2022 11:25:27
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi Davide. Great idea. These functions can be very useful for translating matlab programs. They can also be extended to arrays, as the all, any and nnz functions do.
