1 страниц (7 вхождений)
Multiple Binary Boolean Operators in if statement - Add multiple binary Boolean "or" / "and" operators without force parenthesis - Сообщения
#1 Опубликовано: 06.05.2022 22:53:10
When I try to perform this if-or statement:
if a=1 ^ a=2 ^ a=3
x=4
else x =5
I end up with this due to forced parenthesis:
if ((a=1 ^ a=2) ^ a=3)
x=4
else x =5
Could we have capability for multiple binary operators without forced parenthesis enclosure?
if a=1 ^ a=2 ^ a=3
x=4
else x =5
x=4
else x =5
#2 Опубликовано: 07.05.2022 00:27:03
Hi. The short and honest answer is not. The long and tricky answer is that you can, but you must edit the .sm file and delete the lines with (
However, unless it's for some publishing purpose or something like that, I don't think it's convenient. Also, you can neither copy nor edit it without the parentheses reappearing.
and_tryck.sm (2 КиБ) скачан 69 раз(а).
#3 Опубликовано: 07.05.2022 08:59:32
#4 Опубликовано: 09.05.2022 08:01:56
WroteThink in term of productive Bolean.
... lot more involved. Adapted from Frank Rioux MCD 11.
Fourier Quantum 2C Mask.sm (22 КиБ) скачан 60 раз(а).
#6 Опубликовано: 09.05.2022 10:06:38
WroteYou can always create some function to make it look like you are working with some set of numbers
Tanks Davide ... coded/saved.
Take care ... Jean.
Maths Conditional Davide.sm (12 КиБ) скачан 71 раз(а).
sergio 09.05.2022 12:46:00
#7 Опубликовано: 09.05.2022 11:25:27
Новые сообщения
Нет новых сообщений
