To find eigen vector and eigen values of matrix
To find eigen vector and eigen values of matrix - eigen vector don not satisfy the orthogonality - Сообщения
#1 Опубликовано: 26.04.2022 12:44:25
Dr Chittaranjan Ghosh
I face a problem in finding the eigen vector of matrix. It generates eigen value properly but unable to find correct eigen vector.
The given a 5x5 matrix is
A=[ 0.1151 -8.571*10^{-18} 0.1638 -2.7427*10^{-17} 0.0546
-8.571*10^{-18} 0.3436 -3.2727*10^{-17} 0.2184 9.7954*10^{-18}
0.1638 -3.2727*10^{-17} 0.506 0 0.1638
-2.7427*10^{-17} 0.2184 0 0.6025 2.4242*10^{-17}
0.0546 9.7954*10^{-18} 0.1638 2.4242*10^{-17} 0.7639 ]
Using code as given in Introduction to the use of SMath Studio
Prepared by Gilberto E. Urroz, May 2010 in appendix 7 , the eigen values mat(0.0555,0.2192,0.4657,0.7266,0.8637) are correct which are compared with scilab and python but eigen vector is incorrect? All the eigen vectors do not obey orthogonality properties. How to got correct eigen vector?
#2 Опубликовано: 26.04.2022 14:45:48
Prepared by Gilberto E. Urroz, May 2010in appendix 7 , the eigen values mat(0.0555,0.2192,0.4657,0.7266,0.8637) are correct which are compared with scilab and python but eigen vector is incorrect? All the eigen vectors do not obey orthogonality properties. How to got correct eigen vector?
It is important to remember that an eigenvector is not a unique thing.
For a given eigenvalue, there are infinitely many eigenvectors.
Glance through these 3 documents.
Maths eigenAll.sm (22 КиБ) скачан 111 раз(а).
Maths eigenAll Companion.sm (63 КиБ) скачан 86 раз(а).
Maths Polyroots_Eigen Copy.sm (128 КиБ) скачан 88 раз(а).
#3 Опубликовано: 02.05.2022 07:27:56
Alvaro Gavilán
Alvaro Gavilán
25 сообщений из 68 понравились пользователям.
Can you attach your worksheet? I will take a look, I've never used the cited program but it seems normal (via characteristic polynomial). Normally I would use Maxima for an eigenvalue problem in SS. That always worked for me, having done some comparisons (my expensive problems being coded in Matlab and Julia).
#4 Опубликовано: 02.05.2022 10:55:02
eigenvector.sm (37 КиБ) скачан 76 раз(а).
Here I am attaching some portion of my the worksheet .
#5 Опубликовано: 02.05.2022 10:59:52
Your good suggestion my problems solved partially. eigen value and eigen vectors are correct but eigenvalues are not in sorted.
I have check if the matrix elements are all integers then the eigen values and hence eigenvector sorted. Here worksheet is attached.EiegenVectoreogenValues.sm (9 КиБ) скачан 67 раз(а).
#6 Опубликовано: 02.05.2022 12:11:47
That is immaterial wrt the possible project suite(s).
Gilberto Urroz sorts same as Matcad.
dn_LinAlgEigenvalues(A) sorts differently, values are same.
As well dn_LinAlgEigenvectors(A) are differently sorted
with different arithmetic sign, but numerical values same.
All those codes create confusion.
Maths eigenAll.sm (39 КиБ) скачан 81 раз(а).
