1 страниц (7 вхождений)
Admittance [Bode plot] - Admittance [Bode plot] - Сообщения
#1 Опубликовано: 20.05.2018 19:46:13
The ZedGraph log did crash my Smath session.
Otherwise Bode data set is 1/1 MCD.
Project Admittance Copy.sm (47 КиБ) скачан 137 раз(а).
#2 Опубликовано: 21.05.2018 09:59:57
WroteThe ZedGraph log did crash my Smath session.
Fixed for ZedGraph in attached. Zedgraph inputs only accept two columns. One must adjust points/line settings within the formatting window settings.
Project Admittance Copy_alyles.sm (90 КиБ) скачан 118 раз(а).
#3 Опубликовано: 21.05.2018 11:45:19
WroteFixed for ZedGraph in attached.Zedgraph inputs only accept two columns. One must adjust points/line settings within the formatting window settings.
Thanks alyles, just doctored before your attachment.
I noticed ZedGraph does not support spline, unlike ordinary XY.
Project Admittance.sm (87 КиБ) скачан 102 раз(а).
#4 Опубликовано: 21.05.2018 21:36:17
... [suite]
this Smath document has been doctored/finished for publishing.
Bode gain plot, phase plot ... both log plot X direction.
Project Admittance Copy.sm (150 КиБ) скачан 121 раз(а).
#5 Опубликовано: 22.05.2018 10:58:42
#6 Опубликовано: 22.05.2018 13:32:28
Figured out how to use Maxima's Draw2D(). This also looks nice for a logx plot. Plotted both Admittance and Phase in same graph. I like this as well because properties can be changed directly in SMath sheet.
I played around with XY Plot but was unable to find a way to use log axes.
Project Admittance Copy_Maxima_Draw2D_alyles.sm (183 КиБ) скачан 136 раз(а).
#7 Опубликовано: 22.05.2018 13:55:59
Nice example!
I did a bit of cleanup, removed the markers and shifted some options to the settings dialog.
![2018-05-22 18_50_32-SMath Studio - [Project%20Admittance%20Copy_Maxima_Draw2D_alyles_Kr.sm_].png](/ru-RU/file/wLcyFy/2018-05-22-18_50_32-SMath-Studio---_Project_20Admittance_20Copy_Maxima_Draw2D_alyles_Kr_sm___png)
Project%20Admittance%20Copy_Maxima_Draw2D_alyles_Kr.sm (97 КиБ) скачан 186 раз(а).
Davide Carpi 23.05.2018 06:09:00, frapuano 22.05.2018 18:26:00, Arie 22.05.2018 14:22:00, sergio 22.05.2018 15:00:00
Новые сообщения
Нет новых сообщений
