1 страниц (4 вхождений)
Triangular Mesh for 3D plots - Сообщения
#1 Опубликовано: 23.10.2021 02:42:13
Hi. There are several variants for the triangular meshs. This is one.
pTriMesh.pdf (459 КиБ) скачан 78 раз(а).
pTriMesh.sm (29 КиБ) скачан 84 раз(а).
#2 Опубликовано: 25.10.2021 03:40:35
Hi. Here are some notes about how the mesh is constructed. To include the missing vertices, they would have to be inserted at least twice, when drawing the diagonals. It could be done by constructing the mesh as it is, and instead of drawing the entire diagonal, to the center of the squares, but it could be a slow procedure. For another example, please see https://en.smath.com/forum/yaf_postsm74527_Offset-surface-creation.aspx#post74527
pTriMesh work.sm (28 КиБ) скачан 76 раз(а).
#3 Опубликовано: 25.10.2021 21:28:47
This other have the intesections as part of the mesh.
pTriMesh_v2.sm (48 КиБ) скачан 67 раз(а).
#4 Опубликовано: 18.11.2021 02:12:26
Hi. More general mesh utility, with a variable patern. Also, waterfall plots (matlab page here).
pWMesh.sm (193 КиБ) скачан 80 раз(а).
pWMesh.pdf (3 МиБ) скачан 65 раз(а).
Новые сообщения
Нет новых сообщений
