2D Plot application
2D Plot application - Сообщения
#1 Опубликовано: 17.08.2013 01:58:11
Here is a basic heatmap function.
EDIT: Updated, round(1) replaced by round(2) in order to avoid hidden dependencies to mathlib.dll via EFI plugin.
heatmap.sm (18 КиБ) скачан 173 раз(а).
#2 Опубликовано: 17.08.2013 05:51:28
kilele
kilele
133 сообщений из 397 понравились пользователям.
Nice! It reminds me of this other heat map. See the video. There is a download link of the javascript on the youtube description.
#3 Опубликовано: 17.08.2013 06:26:08
Yes, the example is one of the category "how to solve a problem in SMath that I would not have without SMath". Personally, I prefer gnuplot or matlab for real plotting, although the XY-Plot-Plugin is quite fine for the use cases it can handle (heat map not being among them). I intend to use the function for visualization of matrix population, e.g. for the stiffness matrix of a finite element model.
Davide Carpi 17.08.2013 08:51:00, Fridel Selitsky 17.08.2013 08:57:00
#4 Опубликовано: 17.08.2013 08:51:55
Very nice,
there's the round() function to fix (round(2) instead of the inexistent round(1))
best regards,
Davide
#5 Опубликовано: 17.08.2013 09:37:38
round(1) is from the mathlib.dll via EFI for SMath Studio plugin, which is pre-installed in the inofficial distribution ("SMath with plugins" wiki page).
#6 Опубликовано: 17.08.2013 09:48:02
Ok (The worksheet doesn't contains the EFI in the tag, so the notification does not appears)
#7 Опубликовано: 17.08.2013 10:02:02
I guess that the dependency finder is not aware of what the EFI plugin loads in the background. However, I changed the example to rely on round(1) only.
