1 страниц (5 вхождений)
[SS-2436] Boolean Operator using Text and Numbers - Understanding if statements when using Boolean operators with text and numbers - Сообщения
#1 Опубликовано: 06.03.2017 18:01:32
Why is it that within an if statement I can use a Boolean equal sign to compare objects to a number, but if I try to compare numbers to text I get an error stating that the action could not be performed with text.
See attached.
Boolean Operator - Text and Number.sm (9 КиБ) скачан 73 раз(а).
See attached.
#2 Опубликовано: 06.03.2017 22:51:13
#3 Опубликовано: 06.03.2017 23:26:04
Ah yes, I should have been more specific.
It seems odd to me that the if you compare text to a number the Boolean decides that the text does not equal the number so it executes "as expected". However, if you compare a number to text there is an error thrown. Clearly the text is not the number so why not behave in the same manor?
Thanks for the response, btw.
#4 Опубликовано: 07.03.2017 07:01:20
Seems a bug to me. At first glance it happens only if the number in the comparison comes from el() and is not the first matrix element.
#5 Опубликовано: 07.03.2017 08:42:04
Few modules in this work sheet, may be useful.
Sorry : unrecorded source/originator.
Utilities Matrix IsArray.sm (20 КиБ) скачан 62 раз(а).
Новые сообщения
Нет новых сообщений
