While loop question
While loop question - Сообщения
#1 Опубликовано: 06.04.2023 18:28:44
Razvan
Razvan
Hello everybody,
I'm really new to Smath and i am having an issue with the while loop. How can you write multiple conditions for your while loop. While a>b && b>c && c>d.
Would really appreciate some input.
#2 Опубликовано: 06.04.2023 19:44:47
How can you write multiple conditions ...
If you want to piece wise plot conditional ...
if/otherwise ... as any as you want to condition.
From the directed visit Samples, iterative is bidirectional.
Or multiple conditional Golden ratio
More advanced conditional is generally Bolean... Example attached.
Show something of your Creation.
Critical Triplet Demo.sm (16 КиБ) скачан 60 раз(а).
#3 Опубликовано: 07.04.2023 00:10:14
⚜ Kenny Lemens, P.E. ᵂᴵ
74 сообщений из 164 понравились пользователям.
Greetings!
Hello everybody,
In the boolean toolbar, you will notice "AND" and "OR" operators, denoted as ⋀ & ⋁ (respectively).
On that note, to specify more then (1) command under your while loop; utilize the "line(" command.
As such, you can copy and paste the following:
line(a:20,b:5,c:1,d:0,while(((a>b)&(b>c))&(c>d),line(cc+(b:b+5)),a:a+1,d:b*(-1),3,1)),stack(a,b,c,d),6,1)=#
I hope this is of Good Help;
- Kenny Lemens, P.E. ᵂᴵ
#4 Опубликовано: 07.04.2023 02:28:10
Razvan
Razvan
Cheers, thanks!
#5 Опубликовано: 07.04.2023 16:12:52
... Bolean composite style.
#6 Опубликовано: 07.04.2023 16:33:31
There are also;
ltlt(), altle(), alelt(), a≤blele(), a≤b≤c
gtgt(), a>b>c
gtge(), a>b≥c
gegt(), a≥b>c
gege(), a≥b≥c
These functions are part of Custom Functions plugin.
Unfortunately, it supports only three arguments.
Despite that, some boolean expressions may shorten drastically.
line(a:20,b:5,c:1,d:0,while((gtgt(b,a,c))&(c>d),line(cc+(b:b+5)),a:a+1,d:b*(-1),3,1)),stack(a,b,c,d),6,1)=#
João Felipe Seráfico Melo 08.04.2023 14:45:00
#7 Опубликовано: 08.04.2023 10:17:59
I've never thought about it, but I think that maybe I can add set of functions with unlimited arguments (>1), gt(#) ge(#) lt(#) le(#)
João Felipe Seráfico Melo 08.04.2023 14:45:00, overlord 08.04.2023 16:19:00
#8 Опубликовано: 08.04.2023 14:08:03
... adapt the out maths to your project.
#9 Опубликовано: 08.04.2023 16:20:10
Would unlimited versions be mixed or same boolean expression?
#10 Опубликовано: 08.04.2023 17:52:11
... interesting, however very multiple-specific.
#11 Опубликовано: 08.04.2023 21:22:45
Alvaro Diaz Falconi
Alvaro Diaz Falconi
In addition to gt(#) ge(#) lt(#) le(#), some notes about a relseq function.
relseq.sm (24 КиБ) скачан 62 раз(а).
Mark R Harris 09.04.2023 00:59:00, sergio 10.04.2023 06:28:00
#12 Опубликовано: 11.04.2023 06:03:38
that way, it would be same boolean
lt(a,b,c,d,e,f)=a<b<c<d<e<f=(a<b)&(b<c)&(c<d)&(d<e)&(e<f)
That's a good concept, I think that probaly it's feasible. I'll give it a try.
João Felipe Seráfico Melo 11.04.2023 08:34:00, Alvaro Diaz Falconi 11.04.2023 10:04:00
#13 Опубликовано: 13.04.2023 02:45:33
Alvaro Diaz Falconi
Alvaro Diaz Falconi
... I'll give it a try.
Hi Davide. Something like this other?
#14 Опубликовано: 18.04.2023 07:23:00
this maybe?
also, prefix/postfix functions can be made for unlimited arguments.
I've tried something like postfix(F,x,y) but it isn't really user-friendly (e.g. it can't be used on the LHS of an assignment because it overvrites the postfix() function itself)
Alvaro Diaz Falconi 18.04.2023 12:22:00
#15 Опубликовано: 18.04.2023 12:25:44
Alvaro Diaz Falconi
Alvaro Diaz Falconi
... this maybe? ..
Hi Davide. Great implementation. But I'm thinking in ways to write set union a U b, intersection, function composition like f o g (x) := f(g(x)), logical binary operators like implies, iif and similar stuff.
