Stable: SMath Studio 0.99.7610 (01 November 2020)
Stable: SMath Studio 0.99.7610 (01 November 2020) - Сообщения
#1 Опубликовано: 31.10.2020 18:46:52
2270 сообщений из 3734 понравились пользователям.
Группа: Super Administrator
Changes introduced in current build 0.99.7610
Улучшения
  • Program start up speed significantly improved;
  • The following units added: klx, μT, mT, klm, μWb, mWb;
  • Toolbox icons vectorized;
  • Cloud: SVG icons for toolboxes in supported now;
  • Better support implemented for OS dark mode.
Исправления
  • Support for high dpi systems restored;
  • importData() function improved to support special chars in path;
  • Ohm unit representation fixed for Russian localization;
  • Android: Scaled images supported now;
  • Android: Filling in a text is fixed for some onscreen keyboards;
  • Working with images on Linux fixed (save/open, copy/paste);
  • Color of the underlined text corrected;
  • Text which contains link shown underlined again;
  • Toolbox icons made visible on Mono;
  • Export to PDF fixed on Linux;
  • Cloud: All units/function selection fixed into insert dialog;
  • Splash screen layout fixed on Linux.
Разное
  • Worksheets rendering quality normalized between Mono and .Net frameworks;
  • Refactoring.
Download
SMathStudioDesktop.0_99_7610.Mono.tar.gz (1 МиБ) скачан 36953 раз(а).
SMathStudioDesktop.0_99_7610.Setup.msi (2 МиБ) скачан 87420 раз(а).
System requirements
  • Desktop (Windows):
  • Desktop (Linux):
Interface languages (37 languages)
  • [ARA] Arabic / العربي
  • [BEL] Belarusian / Беларуская
  • [BUL] Bulgarian / Български
  • [CAT] Catalan / Català
  • [CZE] Czech / Čeština
  • [DAN] Danish / Dansk
  • [DUT] Dutch / Nederlands
  • [ENG] English / English
  • [FAS] Persian / فارسی
  • [FIN] Finnish / Suomi
  • [FRE] French / Français
  • [GER] German / Deutsch
  • [GRE] Greek / Ελληνικά
  • [HEB] Hebrew / עברית
  • [HUN] Hungarian / Magyar
  • [IND] Indonesian / Bahasa Indonesia
  • [ITA] Italian / Italiano
  • [JPN] Japanese / 日本語
  • [KOR] Korean / 한국어
  • [LAV] Latvian / Latviešu
  • [LTH] Lithuanian / Lietuvių
  • [NOR] Norwegian / Norsk
  • [POL] Polish / Polski
  • [RON] Romanian / Română
  • [RUS] Russian / Русский
  • [SCC] Serbian (Latin) / Srpski
  • [SCR] Croatian / Hrvatski
  • [SLK] Slovak / Slovenčina
  • [SPA] Spanish / Español
  • [SRP] Serbian (Cyrillic) / Српски
  • [SWE] Swedish / Svenska
  • [TUR] Turkish / Türkçe
  • [UKR] Ukrainian / Українська
Tutorial
  • SMathPrimer.pdf (Date: 11.11.2011. File size: 2.06MB) - to open in Adobe Acrobat Reader
Other files
SMath Studio icons () of all available sizes (16x16, 24x24, 32x32, 48x48, 64x64, 96x96, 128x128, 256x256) in PNG format.
Igor Skarine 31.10.2020 21:22:00, NDTM Amarasekera 01.11.2020 06:36:00, sergio 01.11.2020 12:25:00, IVR 03.11.2020 07:02:00, Serg 06.11.2020 13:59:00
#2 Опубликовано: 31.10.2020 21:22:53
Igor Skarine
Igor Skarine
14 сообщений из 97 понравились пользователям.
Can't work with EFI plugin.
#3 Опубликовано: 01.11.2020 00:50:36
1402 сообщений из 1708 понравились пользователям.
Last EFI build is experimental. I will remove it. I asked Andrey to check one bug.
#4 Опубликовано: 01.11.2020 04:02:46
I see that the following plug-ins handles 0 (zero) functions now:
- efi
- dislin
- matlab c++
- octave c++
- probe properties
Regarding efi: I'm looking at the issue right now.
#5 Опубликовано: 01.11.2020 04:41:13
- efi
- dislin
- matlab c++
- octave c++
- probe properties
Prode Properties: You need to install Prode first. The plugin is just a wrapper.
Matlab C++ Math Library: For x32 only, but I have one idea how to make x64 support available.
Mathcad EFI: Also only for x32, but it is possible to make x64 support.
DISLIN: The library itself has recently been updated. I will try to update the plugin by changing the way the functions are loaded.
Octave C++ Math Library: Also only 32-bit Octave library exists.
Andrey Ivashov 01.11.2020 06:29:00
#6 Опубликовано: 01.11.2020 05:36:38
Also maple don't work under linux with mono.
Edit: Nevermind, I have posted a solution for this.
https://en.smath.com/forum/yaf_postsm67797_Maple-Tools.aspx#post67797
#7 Опубликовано: 01.03.2021 12:17:23
montee248
montee248
Hi everyone
I'm struggling with installation, unfortunately there is some error that I can't solve. I checked .NET Framework, try to reboot but it appears everytime. I'm working on Win 10 x64 ver. 1809
Is there somebody who might have an idea how to resolve it?
Older versions of SMath also struggles with the same problem ;/
Thanks for help
