[SS-125] Chinese words input
[SS-125] Chinese words input - Сообщения
#1 Опубликовано: 10.07.2012 09:09:03
wbrwbr2012
wbrwbr2012
1 сообщений из 2 понравились пользователям.
Thanks for the great application. Since it seems that I have no rights to post on other forums, I have to post an issue here. I apologize if it bothers you.
I am Chinese. So when I play with Smath, I'd like to insert text region with Chinese words. But every time I enter a Chinese word, I always get the text region with the words doubled after clicking the Enter key. For example, I want to input the words "中国", so I switch to use some Chinese word input method, after choosing the correct words in the input method panel, I hit the "Enter" key, and Smath gets "中国中国". Hope I have explained the issue clearly.
Thanks very much.
#2 Опубликовано: 22.04.2014 22:20:30
wbrwbr2012
wbrwbr2012
Perhaps I'm the only Chinese person on the forum. I am still annoyed with this issue. So I tried to find the solution. Accidentally I get one post from other forum. It has nothing to do with Smath. But I'd like to give description.
Inherit a custom control from the Control class, and overload OnKeyPress event, When you enter text using Chinese input method,the OnKeyPress event will be triggered twice. The reason is that after the OnKeyPress treatment, there is no set for e.Handled = true;
This attribute value indicates whether you get and handle this event. If not set, the system will trigger the event again.
Hope this help.
Davide Carpi 23.04.2014 03:53:00
#3 Опубликовано: 23.04.2014 07:00:12
Hello, wbrwbr2012
I've reproduced your issue with the on-screen keyboard and I've added the bug in the BTS (Bug Tracking System) as SS-125
To augment the visibility of this bug you can vote it (you need a new registration in the BTS, violet button on the top of this page)
Best regards,
Davide
#4 Опубликовано: 22.11.2015 21:43:45
Noah
Noah
This bug is still exist on Windows 8/8.1/10 when I use Microsoft IME to input Chinese.
Smath Studio version:0.97.5737
