UPDATED: SMath Studio 0.98.6593 (19 January 2018)
UPDATED: SMath Studio 0.98.6593 (19 January 2018) - Сообщения
#1 Опубликовано: 06.01.2018 08:08:31
2270 сообщений из 3734 понравились пользователям.
Группа: Super Administrator
List of changes(between 0.98.6580 and 0.98.6593 versions)
Download
SMathStudioDesktop.0_98_6593.Mono.tar.gz (1 МиБ) скачан 712 раз(а).
SMathStudioDesktop.0_98_6593.Setup.msi (2 МиБ) скачан 1875 раз(а).
10 пользователям понравился этот пост
Serg 11.01.2018 07:38:00, NDTM Amarasekera 06.01.2018 08:13:00, frapuano 06.01.2018 08:28:00, IVR 06.01.2018 11:13:00, sergio 06.01.2018 12:29:00, Radovan Omorjan 06.01.2018 13:34:00, Davide Carpi 06.01.2018 14:58:00, Igor Skarine 06.01.2018 19:23:00, Василий Николаевич Храмушин 10.01.2018 14:23:00, Denis Nikitin 11.01.2018 03:16:00
#2 Опубликовано: 06.01.2018 11:37:02
Please confirm this version works well on Linux (please report OS version).
Thanks in advance!
#3 Опубликовано: 06.01.2018 15:11:53
for(2) still glitchy while nested, linux version ok for me
Andrey Ivashov 11.01.2018 15:33:00
#4 Опубликовано: 06.01.2018 17:02:31
philippe dalet
philippe dalet
18 сообщений из 34 понравились пользователям.
Thanks in advance!
Tested on Ubuntu 16.04 64 bits cinnamon + mono 5.4.1.6
it starts well.
- [AppDir] Special Functions 1.11.6580.5369 (4 ms.)
- [UserDir] Mathcad File Access Functions 1.0.6520.39061 (12 ms.)
- [UserDir] Custom Functions 1.1.6522.6678 (7 ms.)
- [UserDir] 3D Plot Region (Chart3DLib) 0.1.6520.38983 (38 ms.)
- [UserDir] Maple Wrapper 1.0.6520.39056 (183 ms.)
- [UserDir] Nonlinear Solvers 1.1.6353.25410 (28 ms.)
- [UserDir] X-Y Plot Region (Chart2DLib) 0.1.6520.39122 (7 ms.)
- [AppDir] HTML Export 1.13.6580.5369 (1 ms.)
- [AppDir] Export to image 1.9.6580.5370 (0 ms.)
- [AppDir] Picture Region 1.10.6580.5369 (1 ms.)
- [AppDir] Plot Region 1.9.6580.5370 (2 ms.)
- [AppDir] SMath Studio Files Plugin 1.9.6580.5370 (1 ms.)
- [AppDir] Standard Toolbox Buttons 1.0.6580.5370 (0 ms.)
- [AppDir] Text Region 1.10.6580.5369 (1 ms.)
- [AppDir] SMath Viewer Files Plugin 1.1.6580.5370 (1 ms.)
- [AppDir] XMCD Files Plugin 1.12.6580.5370 (1 ms.)
When I type d:=1 , it quits
When I load a file (.sm) , the program has no text, only graphs. I have to stop the process by Htop.
System.NullReferenceException: Object reference not set to an instance of an object
at SMath.Control.PaintContext.DrawString (System.String text, System.Drawing.Font font, System.Single size, System.Drawing.FontStyle style, System.Drawing.Brush br, System.Single x, System.Single y, SMath.Manager.TermType type) [0x000a3] in <1e60c22eb2d744188ab78889b4b8509b>:0
at SMath.Control.PaintContext.DrawTerm (System.String text, System.Drawing.Brush brush, System.Drawing.Point location, System.Int32 x1, System.Int32 y1) [0x000ba] in <1e60c22eb2d744188ab78889b4b8509b>:0
at SMath.Control.PaintContext.DrawTerm (SMath.Control.DrawMemory mem, System.String text, System.Int32 x1, System.Int32 y1, System.Int32 brushNo, System.Boolean useCustomBrush) [0x00104] in <1e60c22eb2d744188ab78889b4b8509b>:0
at SMath.Control.MathPainter.Paint (SMath.Control.MathRegion region, SMath.Control.PaintContext ctx, System.Int32[] watch, System.Int32[] sel, System.Int32& LC, System.Int32 ErrorTerm, System.Boolean Focused) [0x007de] in <1e60c22eb2d744188ab78889b4b8509b>:0
at SMath.Control.MathRegion.OnPaintEx (System.Windows.Forms.PaintEventArgs e) [0x0003e] in <1e60c22eb2d744188ab78889b4b8509b>:0
at SMath.Control.MathRegion.Prepare (System.Drawing.Graphics g, System.Windows.Forms.PaintEventArgs e) [0x000e3] in <1e60c22eb2d744188ab78889b4b8509b>:0
at SMath.Control.MathRegion.OnPaint (System.Windows.Forms.PaintEventArgs e) [0x00000] in <1e60c22eb2d744188ab78889b4b8509b>:0
at SMath.Control.RegionBase.DrawToBitmap (System.Drawing.Color bgColor, System.Boolean ctrlFocused) [0x000ba] in <1e60c22eb2d744188ab78889b4b8509b>:0
at SMath.Control.RegionBase.DrawToBitmap () [0x00006] in <1e60c22eb2d744188ab78889b4b8509b>:0
at SMath.Control.MathRegion.TryGetTooltip (System.Drawing.Bitmap& bmp) [0x001b2] in <1e60c22eb2d744188ab78889b4b8509b>:0
at SMath.Control.Worksheet.GetCurrentTooltip (System.Int32 index) [0x00033] in <1e60c22eb2d744188ab78889b4b8509b>:0
at (wrapper remoting-invoke-with-check) SMath.Control.Worksheet:GetCurrentTooltip (int)
at . (System.Object , System.Windows.Forms.MouseEventArgs ) [0x0003c] in <94cdadf5fe92498fbd75e5657b65a92e>:0
at System.Windows.Forms.Control.OnMouseMove (System.Windows.Forms.MouseEventArgs e) [0x00019] in :0
at SMath.Control.WorksheetControl.OnMouseMove (System.Windows.Forms.MouseEventArgs e) [0x00007] in <1e60c22eb2d744188ab78889b4b8509b>:0
at System.Windows.Forms.Control.WmMouseMove (System.Windows.Forms.Message& m) [0x000a5] in :0
at System.Windows.Forms.Control.WndProc (System.Windows.Forms.Message& m) [0x0020c] in :0
at System.Windows.Forms.Control+ControlWindowTarget.OnMessage (System.Windows.Forms.Message& m) [0x00000] in :0
at System.Windows.Forms.Control+ControlNativeWindow.WndProc (System.Windows.Forms.Message& m) [0x0000b] in :0
at System.Windows.Forms.NativeWindow.WndProc (System.IntPtr hWnd, System.Windows.Forms.Msg msg, System.IntPtr wParam, System.IntPtr lParam) [0x00085] in :0
Philippe DALET
FRANCE
#5 Опубликовано: 08.01.2018 09:25:00
- parenthesis (including matrices, etc) are fixed.
- definition operator (:=) issue is fixed.
- range(3) has glitch. range dots does not appear
just between two numbers if it is used after a
definition operator or inside of for, sys, line etc.
no problem if range(3) is written alone.
regards
#6 Опубликовано: 10.01.2018 13:39:24
New version of SMath Studio 0.98.6584 released. Topic updated.
Please test on Linux with Mono. Thanks in advance!
Denis Nikitin 11.01.2018 03:17:00, Serg 11.01.2018 07:35:00
#7 Опубликовано: 11.01.2018 15:31:03
New version of SMath Studio 0.98.6585 released. Topic updated.
Davide Carpi 11.01.2018 17:06:00, frapuano 11.01.2018 19:50:00
#8 Опубликовано: 11.01.2018 20:14:34
SMath Studio: SMath Studio Desktop 0.98.6585.18710, x64
OS: Unix 3.16.0.38 (friendly name not found, x64)
Screen: 1662x928 px, 96x96 dpi, 96 GP.DPI, 1 GP.SRF
Localization: separator=; decimal symbol=; system decimal symbol=; language=ENG
Frameworks: MONO 4.2.2 (Stable 4.2.2.30/996df3c Mon Feb 15 17:30:30 UTC 2016)
Mint 17.2 on a Virtual box.
I get a strange error: The context menu doesn't close and stick in the foreground. This is triggered by trying to zoom the canvas by ctrl-drag middle mouse button (Lenovo thinkpad trackpoint). The menu windows don't vanish when the program is closed. They only vanish if the temporary terminal window is closed as well.
There is no way to zoom the canvas with trackpoint or trackpad. I have to use the status bar zoom menu for zooming.
Under Windows I can use two-finger guestures on the trackpad to zoom.
This may be due to insufficient hardware support in the linux box.
BTW 6580 crashed when I started typing to the canvas. This problem is solved now even though my mono might not be up to date.
2018-01-11 23_59_09-Mint_Mate_Mech_2015_10_30 [wird ausgefuhrt] - Oracle VM VirtualBox.png
Andrey Ivashov 12.01.2018 00:46:00
#9 Опубликовано: 12.01.2018 20:38:18
David Avila Cortes
David Avila Cortes
1 сообщений из 2 понравились пользователям.
Ubuntu 17.10 Gnome 3.26.2 64-bit
Mono JIT compiler version 5.4.1.6 (tarball Wed Nov 8 20:37:08 UTC 2017)
it works well overall, a few graphical bugs like white patches on the notebook background that disappear when dragging a selection box over them, the big bug that persist is the Data exchange plug-in, I just cant get it to work properly when I try to save my files as a XELATEX document, it will either crash immediately, display improperly the options box or simply display errors on the console.
Only when keeping the smath app window unmaximized and with all other windows minimized have I been able to save the file properly it doesn't always work though
Andrey Ivashov 13.01.2018 10:41:00
#10 Опубликовано: 12.01.2018 22:22:38
Thank you I wasn't aware of this bug (hope I've not forget it if was mentioned in this forum before ), I'll take a look on it ASAP.
#11 Опубликовано: 14.01.2018 19:24:02
tomracing
tomracing
8 сообщений из 16 понравились пользователям.
Tried the new version today on Arch Linux using KDE plasma and dark themes.
Seeing a message in the terminal that assumes Gtk theme:
mono:13865): Gtk-WARNING **: Unable to locate theme engine in module_path: "adwaita",
(mono:13865): Gtk-WARNING **: Unable to locate theme engine in module_path: "adwaita",
also the formulas look a little funky
Andrey Ivashov 15.01.2018 03:40:00
#12 Опубликовано: 15.01.2018 03:40:16
New version of SMath Studio 0.98.6588 released. Topic updated.
6 пользователям понравился этот пост
sergio 15.01.2018 08:40:00, NDTM Amarasekera 15.01.2018 08:55:00, frapuano 15.01.2018 09:24:00, Igor Skarine 15.01.2018 10:35:00, Davide Carpi 16.01.2018 05:34:00, IVR 16.01.2018 15:48:00
#13 Опубликовано: 17.01.2018 03:52:32
New version of SMath Studio 0.98.6590 released. Topic updated.
Radovan Omorjan 17.01.2018 04:35:00, Martin Kraska 17.01.2018 05:50:00, Denis Nikitin 17.01.2018 09:15:00
#14 Опубликовано: 17.01.2018 04:42:23
Hmm...A strange thing happens with this version for me (Win 7 64bit).
When I want to insert a matrix, say A: and press CTRL+M, then the mouse pointer disappears (not visible)???
Then I press ESC, and by repeating CTRL+M, everything is Ok. I can Insert a matrix then and the mouse pointer is here and visible.
This is not the case when choosing from the menu: Insert->Matrix.
#15 Опубликовано: 17.01.2018 05:04:20
I have experienced a similar issue with these beta versions too (mouse invisible) when opening new worksheets with CTRL+N and regions focused, not yet found a way to reproduce (sometimes happens, sometimes not). Win7 and Win10.
#16 Опубликовано: 17.01.2018 05:49:39
Really nice!
Andrey Ivashov 17.01.2018 13:23:00
#17 Опубликовано: 17.01.2018 13:27:40
Thank you! I think I've found the reason, so next nightly build will contain an appropriate fix.
When I want to insert a matrix, say A: and press CTRL M, then the mouse pointer disappears (not visible)???
Thank you! It is a bug. I have just fixed it. New version will be available tomorrow.
We are on the road to prepare next stable build. Plan is to release it at 1-st February. Two weeks left...
frapuano 17.01.2018 14:41:00, Radovan Omorjan 17.01.2018 14:49:00, sergio 17.01.2018 15:22:00, Davide Carpi 17.01.2018 22:12:00
#18 Опубликовано: 17.01.2018 14:52:46
Really nice!
Yes Martin: very nice !
Now, you committed yourself for more testing, is it .
The very best example is the Mandelbrot set.
If we delete the last line of the complete program,
we can see the nested collection that the final Mij explodes in matrix.
The very original Mathcad [6, 7 ?] was lot more complicated because it
didn't have the Mij LHS Exploder.
Maths Vectorize COMPANION [CreateCollectNestSum].sm (116 КиБ) скачан 106 раз(а).
#19 Опубликовано: 17.01.2018 15:02:25
... back to snippet above: I wonder if it could be done so cleanly MCD 11.
You see black, but it is not completely black [1,1,1].
From observation black [0,0,0] freaked many things in the work sheet.
Pure observation for convenience.
#20 Опубликовано: 17.01.2018 16:43:06
New version of SMath Studio 0.98.6591 released. Topic updated.
