1 страниц (7 вхождений)
How to obtain the Peak of this example? - Сообщения
#1 Опубликовано: 25.02.2023 04:14:28
Hi, guys:
Here is a formula
And the Targets are:
1. Draw the plot, but only the first quadrant is required.
2. Find the value of fn when M is maximum.
3. Find the maximum value of M.
I did the 1st target successfully, but can not find the values of fn and M. I have tried my best and search the forum but could not find any way to fix it. Please help to fix it, Thank you very much!
LLC.sm (12 КиБ) скачан 44 раз(а).
Here is a formula
#2 Опубликовано: 25.02.2023 09:57:08
WroteWrotePlease help to fix it, Thank you very much!
You need the Golden ratio ... doctored version.
If the function is a data set, spline/smooth the region
... as well the FindIndex is a good utility.
LLC Doctored for MAX.sm (27 КиБ) скачан 38 раз(а).
Golden ratio QUICK Copy.sm (123 КиБ) скачан 38 раз(а).
wow!I think I understand, it is very useful, thank you very much!
#3 Опубликовано: 25.02.2023 14:41:41
The built-in functions are perfectly well suited for the purpose. You just need to separate differentiation from root finding.
LLC.sm (11 КиБ) скачан 46 раз(а).
#4 Опубликовано: 25.02.2023 20:54:24
#5 Опубликовано: 26.02.2023 20:58:40
#6 Опубликовано: 27.02.2023 22:55:02
#7 Опубликовано: 27.02.2023 23:13:37
Новые сообщения
Нет новых сообщений
