1 страниц (4 вхождений)
h(p1, p2) implicit plot - Why I can not create it? - Сообщения
#1 Опубликовано: 19.06.2024 18:34:29
#2 Опубликовано: 22.07.2024 14:59:18
2RegP-Ideal-Cool_Prop.sm (82 КиБ) скачан 70 раз(а).scratch geometry dash
The graph you've provided seems to show a relationship between two pressures 𝑝1and 𝑝2, with annotations related to efficiency calculations.
Axes:𝑝1 on the x-axis (measured in atm). 𝑝2 on the y-axis (measured in atm).
Curves: Different colored curves (red, blue, and green) that might represent different states or processes in a thermodynamic cycle or system, such as isobars, isotherms, or other state transitions.
Water/Steam Cycle: Given the mention of "WaterSteame Pro," this graph might be related to a water/steam cycle analysis, such as a Rankine cycle or steam turbine efficiency calculation.
Efficiency (𝜂): The efficiency calculations likely relate to the performance of a particular component or the overall system under different pressures and temperatures.
The mention of "points > 20 - problems" suggests there might be issues with the data points or calculations when exceeding a certain number of data points.
Valery Ochkov 22.07.2024 17:02:00
#3 Опубликовано: 24.07.2024 13:29:16
Hi. You can use the Draghilev's method for parametrize a curve.
2RegP-Ideal-Cool_Prop (1).sm (82 КиБ) скачан 72 раз(а).
2RegP-Ideal-Cool_Prop (1).pdf (317 КиБ) скачан 70 раз(а).
#4 Опубликовано: 05.08.2024 13:51:05
Новые сообщения
Нет новых сообщений
