augment() and stack()
augment() and stack() - Сообщения
#1 Опубликовано: 14.04.2012 14:09:43
Hello Andrey,
I wonder if the augment() and stack() could be made to receive a scalar argument in the case of merging vectors and scalars. This is not working at the moment *Array dimensions do not match*:
[MATH=eng]c:mat(x,y,z,1,3)[/MATH]
[MATH=eng]augment(a,b,c)=#@#[/MATH]
[MATH=eng]stack(a,b,transpose(c))=#@#[/MATH]
But this will:
[MATH=eng]c:mat(x,y,z,1,3)[/MATH] [MATH=eng]a:mat(a,1,1)[/MATH] [MATH=eng]b:mat(b,1,1)[/MATH]
[MATH=eng]augment(a,b,c)=mat(a,b,x,y,z,1,5)[/MATH]
[MATH=eng]stack(a,b,transpose(c))=mat(a,b,x,y,z,5,1)[/MATH]
We had to make "a" and "b" variables as single element vectors. It seems to me a bit redundant. Andrey, could you make that augment() and stack() could have scalars as their arguments as well, in the cases of merging row or column matrices (vectors)?
Davide Carpi 16.06.2012 16:37:00
#2 Опубликовано: 17.06.2012 06:21:45
Группа: Super Administrator
Hello Radovan.
I've checked what could be done with stack/augment to fix issues you are mentioned and I've made corrections to your approach: symbolic engine will not either evaluate augment/stack functions or raise an exception if dimensions of the arguments don't match. It will pass these functions to allow numeric engine make a final decision about what is error and what is not.
Please see Use case section of the screenshot below for understanding the reasons.
Davide Carpi 17.06.2012 06:25:00, Radovan Omorjan 17.06.2012 07:35:00
#3 Опубликовано: 17.06.2012 07:39:58
Thank you Andrey for this fix
Loking forward to the next release
#4 Опубликовано: 17.06.2012 10:10:19
Hello Andrey,
SMath 0.95 was just released and I must be annoying about this issue. Therefore, I appologize
Just wondering why this could not be possible in v0.95. Why the first element could not be a scalar - it must be a vector.
[MATH=eng]augment(1,mat(2,3,4,1,3))=#@#[/MATH]
[MATH=eng]stack(1,mat(2,3,4,3,1))=#@#[/MATH]
#5 Опубликовано: 17.06.2012 10:29:19
Ahh yes. The separate logic for this case presented in the program... It's my fault. Will be fixed in the next release.
Davide Carpi 17.06.2012 12:47:00
#6 Опубликовано: 17.06.2012 10:40:01
Thank you Andrey ,
BTW, in v0.95 this is possible: stack() and augment() with all scalars - very good
[MATH=eng]augment(1,2,3)=mat(1,2,3,1,3)[/MATH]
[MATH=eng]stack(1,2,3)=mat(1,2,3,3,1)[/MATH]
