Understanding Redlich–Kwong equation of state
Understanding Redlich–Kwong equation of state - Сообщения
#1 Опубликовано: 30.07.2023 13:45:38
usamakhan
usamakhan
3 сообщений из 75 понравились пользователям.
@ https://en.wikipedia.org/wiki/Redlich%E2%80%93Kwong_equation_of_state
I have a question regarding mixture rules of mentioned EOS & particularly the math notation that I could not comprehend
In the attached image what does this Math notation means -- annotated as 1?
e.g if I have x2 species
x1= 0.6 x2=0.4 (mol frac)
a1= 0.16 a2=0.4 (constants)
what does this notation with double summation will do with these values?
Second alternative -- annotated as 2, does it imply following construct?
1] GeomatricAVG = (0.16 * 0.14) ^ 1/2 -- 1/n where n is 2 bcz its a binary mixture
2] A = 0.6 * GeomatricAVG + 0.4 * GeomatricAVG
#2 Опубликовано: 30.07.2023 21:47:31
Alvaro Diaz Falconi
Alvaro Diaz Falconi
992 сообщений из 1674 понравились пользователям.
Hi. It means that, given the relationship between the "a's" of each component and the "a" of the mixture, you need a matrix of interaction coefficients to determine the attractive potential of molecules coefficient for the mixture, which is usually found by assuming that each coefficient in the matrix is the geometric mean of the component coefficients.
A complete example of how the Redlich-Kwong model is used for a mixture in the attached.
Redlich-Kwong.sm (23 КиБ) скачан 79 раз(а).
Redlich-Kwong.pdf (93 КиБ) скачан 88 раз(а).
#3 Опубликовано: 31.07.2023 08:08:07
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Joining above with this other two methods.
Redlich-Kwong - HeXe mix.pdf (136 КиБ) скачан 89 раз(а).
Redlich-Kwong - HeXe mix.sm (59 КиБ) скачан 82 раз(а).
#4 Опубликовано: 31.07.2023 16:42:08
usamakhan
usamakhan
Extremely thanks for your time.
Показать спойлер
I understood. Thanks
#5 Опубликовано: 31.07.2023 18:32:32
Redlich_Kwong is an optimized version of the simpler mixture.
Optimized wrt to coefficients c1,c2 [a,b].
It might be possible to fit mixture vs some Redlich_Kwong data set.
Refactor the graphs Solver 30405.
Inst_Mixture.sm (40 КиБ) скачан 70 раз(а).
#6 Опубликовано: 01.08.2023 16:02:50
usamakhan
usamakhan
I will go through Jean's file in about a day. Thanks Jean for your much needed help.
