1 страниц (5 вхождений)
Help equation Solution - solve equation - Сообщения
#1 Опубликовано: 18.04.2020 07:24:19
#2 Опубликовано: 18.04.2020 07:42:44
WroteI can't solve the equation below, I tried two options but none worked. Someone could help ?
Please: attach the document for the missing data.
#3 Опубликовано: 18.04.2020 11:20:12
Let's start by observing that:
1) the "solve" function is native to smath but does not accept units of measurement (if you want to use it you must temporarily get rid of the units of measurement)
2) the "FindRoot" function you have defined relies on "solve" (see above)
3) in the "nonlinear Solver" plugin you will find a "FindRoot" function that can do for you and that manages the units of measurement
4) there are other features and plugins that can help you. I suggest you also consult Martin Kraska's Interactive SMath Handbook with lots of information and practical examples (you can find it in the tool you use to install plugins)
#4 Опубликовано: 18.04.2020 13:23:01
Yes. It is attached or attached.Modelo_Planilha de Calculos_OM_rev02.sm (2 МиБ) скачан 55 раз(а).
Thank you.
Best Regard.
Elton Freitas
Thank you.
Best Regard.
Elton Freitas
#5 Опубликовано: 18.04.2020 14:11:13
a quadratic equation, solved algebraically?
MPa^2=((σ.solda)/(a.cordao))^(2)+3*((P.total)/(2*h*a.cordao))^(2)
sys(a.cordao≡-sqrt(4*h^2*σ.solda^2+3*P.total^2)/{2*MPa*h},a.cordao≡sqrt(4*h^2*σ.solda^2+3*P.total^2)/{2*MPa*h},2,1)
Новые сообщения
Нет новых сообщений
