Numerical parameterization implicit surfaces of the form f (x, y, z) = 0
Numerical parameterization implicit surfaces of the form f (x, y, z) = 0 - Сообщения
#1 Опубликовано: 29.05.2015 20:25:23
Fridel Selitsky
Fridel Selitsky
The grid lines are found by Draghilev Method
Method 1.
Building a line of intersection of the required surface
with the plane x = 0. This line is rotated in steps of 2 * Pi / s
about a vertical axis by an angle 2 * Pi, where s is the number of steps (the grid lines)
Davide Carpi 31.05.2015 07:19:00
#2 Опубликовано: 29.05.2015 20:39:51
Fridel Selitsky
Fridel Selitsky
Method 2.
The rectangular grid
ELLIPSE3d2.pdf (631 КиБ) скачан 159 раз(а).
#3 Опубликовано: 17.12.2016 18:17:47
Fridel Selitsky
Fridel Selitsky
The graph an implicit surface depicted by lines
Examples of the idea of ​​the algorithm taken from the publication of Alexey Ivanov
http://www.mapleprimes.com/questions/219995-Finding-A-Convinient-Parametrization-Of-Surfaces#answer233804
Файл не найден.Файл не найден.Файл не найден.Файл не найден.Файл не найден.
Вячеслав Мезенцев 19.12.2016 01:43:00, Davide Carpi 18.12.2016 19:04:00, frapuano 18.12.2016 05:42:00
#4 Опубликовано: 29.01.2017 16:56:41
Fridel Selitsky
Fridel Selitsky
Two surfaces are taken from the site
http://xrt.wikidot.com/gallery:implicit
The calculation algorithm:
1.Find the line of intersection of the given surface with the plane Z=0
2.Through each point hold the plane x1 = C and find the line of intersection of that plane with a given surface.These lines represent a given surface.
Davide Carpi 30.01.2017 09:18:00
#5 Опубликовано: 29.01.2017 23:28:16
Thanks for these two animations. In each one, the last three plots
stay red, though the animated plot works fine. A small detail:
each work sheet has three definitions left over at page 17.
#6 Опубликовано: 30.01.2017 03:51:39
Fridel Selitsky
Fridel Selitsky
Thank you Jean,
Worksheets corrected. In addition, in the algorithm for calculating along with x1 = C can be used x2 = C:
double torus x2.sm (73 КиБ) скачан 105 раз(а).
Davide Carpi 30.01.2017 09:18:00, NDTM Amarasekera 30.01.2017 11:30:00
#7 Опубликовано: 31.01.2017 17:50:55
Fridel Selitsky
Fridel Selitsky
The tube in the form of a line of intersection of the cylinder and the torus (See post 7)
http://en.smath.info/forum/yaf_postst2307_Method-A-B--Draghilev-and-animation-spatial-mechanisms.aspx
Time calculation, 9 min.
Villarceau 9.sm (39 КиБ) скачан 93 раз(а).
Davide Carpi 01.02.2017 05:58:00
#8 Опубликовано: 01.03.2017 04:25:37
Fridel Selitsky
Fridel Selitsky
Helical Tube
NonCirc.sm (53 КиБ) скачан 96 раз(а).
TubeCir.sm (53 КиБ) скачан 99 раз(а).
Davide Carpi 01.03.2017 06:42:00
#9 Опубликовано: 01.03.2017 04:44:07
Fridel Selitsky
Fridel Selitsky
The surface of the Wikipedia
https://en.wikipedia.org/wiki/File:Tri-brezel.svg
WiciSurf.sm (106 КиБ) скачан 100 раз(а).
#10 Опубликовано: 14.06.2017 13:27:49
Fridel Selitsky
Fridel Selitsky
Non-circular cylindrical vessels with quasi-ellipsoidal ends
Krivoshapko S.N. Ivanov V.N,Encyclopedia of Analytical Surfaces ,Springer,2015
Non-circular cylindrical vessels.pdf (1 МиБ) скачан 114 раз(а).
Non-circular cylindrical vessels.sm (209 КиБ) скачан 97 раз(а).
Shell1.sm (255 КиБ) скачан 102 раз(а).
Shell2.sm (33 КиБ) скачан 98 раз(а).
Shell3.sm (34 КиБ) скачан 95 раз(а).
#11 Опубликовано: 15.06.2017 09:43:57
Thanks Ber7 for the work sheets [Not finished downloading].
If you visit this document, I'm wondering:
"How to add red points in this plot".
Thanks in advance ... Jean
Maths sph2xyz.sm (13 КиБ) скачан 96 раз(а).
#12 Опубликовано: 15.06.2017 12:23:51
Fridel Selitsky
Fridel Selitsky
Hello Jean,
Unfortunately, the 3d chart does not allow you to draw points.
Exit (hopefully temporary) -make a 3d chart on a 2d chart.
Maths sph2xyz2d.sm (21 КиБ) скачан 106 раз(а).
#13 Опубликовано: 06.02.2018 03:56:52
Fridel Selitsky
Fridel Selitsky
Implicit surfaces in Maxima
ImplicitMaxima.sm (363 КиБ) скачан 100 раз(а).
frapuano 06.02.2018 04:34:00, Martin Kraska 06.02.2018 04:59:00, Radovan Omorjan 06.02.2018 06:22:00
#14 Опубликовано: 06.02.2018 05:06:49
1230 сообщений из 2155 понравились пользователям.
Nice examples!
Just some remarks for those who want to play around with Maxima Draw.
  • Instead of Image region with Draw() command you can use Maxima Draw3D region with interactive zoom, rotation and resize and a settings dialog.
    Insert-> Maxima-> Draw3D
  • The performance isn't overwhelming, as the image is recalculated for each interaction.
  • The snippet "draw" provides help texts for the available draw commands and options.
  • Follow the link in my signature to see how to configure SMath with Maxima.
ImplicitMaxima_Kr.sm (492 КиБ) скачан 101 раз(а).
Вячеслав Мезенцев 06.02.2018 06:15:00, Radovan Omorjan 06.02.2018 06:22:00, frapuano 06.02.2018 10:28:00, Fridel Selitsky 06.02.2018 05:08:00
#15 Опубликовано: 21.02.2018 16:41:18
Fridel Selitsky
Fridel Selitsky
Continuation:
MaximPlus1.sm (237 КиБ) скачан 100 раз(а).
frapuano 21.02.2018 18:56:00
