If Else If Statements
If Else If Statements - How to make an Else If statement - Сообщения
#1 Опубликовано: 13.12.2023 19:30:07
Captain_North
Captain_North
Hello dear Smath Users,
I accidentally pressed the keyboard once and created an Else-If statement like this:
Lately I have been struggling to find this option of an Else If statement on Smath studio.
There seemed to be no information on this topic anywhere.
So I figured it out myself:
--Type "if" and press the TAB key.
--Click in the place above the "Else" portion of the If statement.
--Now press ";" and you should get an If Else-If statement.
Kind Regards!
#2 Опубликовано: 13.12.2023 22:22:09
1. if/else from program palette
2. alternately from fx menu
3. if/otherwise from fx menu cases
#3 Опубликовано: 14.12.2023 00:29:25
You add and remove entries just as within vectors or lists (sys) or command blocks (line). If you don't need command blocks in the entries, then probably the cases() function from the custom functions plugin is more reader-friendly than cascades of if().
#4 Опубликовано: 14.12.2023 05:57:38
Mathcad has if/else in two styles
like Smath and single line => very convenient compactor.
#5 Опубликовано: 14.12.2023 08:43:51
Original if() didn't have else if just over a year ago.
Only persistent else statement existed with one if.
Nowadays you can even eliminate else.
Oscar Campo 18.12.2023 06:16:00
