1 страниц (6 вхождений)
Mathcad to Smath Question - Сообщения
#1 Опубликовано: 26.07.2016 18:06:01
I'm trying to recreate a mathcad calculation in smath and I'm not sure how to make the evaluation "l" which is the resultant distance for each point.
Thanks in advance for any help.
C' Bolt Coefficient.sm (9 КиБ) скачан 64 раз(а).
DownloadDocumentFile.pdf (8 КиБ) скачан 90 раз(а).
#2 Опубликовано: 26.07.2016 20:02:04
Here you go. There might be another way to do this, but this was the first I thought of.
C' Bolt Coefficient revised.sm (11 КиБ) скачан 69 раз(а).
#3 Опубликовано: 26.07.2016 22:55:28
#4 Опубликовано: 27.07.2016 11:20:59
Thanks Ernesto.
@Jean
The next step is to use the C' equation to for each bolt resultant distance to center of group.
I think I've got the C' equation working but I'm sure there is a better way.
C' Bolt Coefficient - 2016-07-27.sm (33 КиБ) скачан 59 раз(а).
@Jean
#5 Опубликовано: 27.07.2016 12:17:10
Wrote"Uncle Sam",
By inspetion, I kind of understand the C' formula,
just a matter to code Smath. Will be back tonight.
What is Δmax ?
Thanks for the help.
Δmax = Maximum deformation on the bolt farthest from the center of gravity.
Empirical set value = 0.34 in
Новые сообщения
Нет новых сообщений
