Inline division
Inline division - Сообщения
#1 Опубликовано: 15.12.2021 23:52:35
Chito
Chito
1 сообщений из 6 понравились пользователям.
Is there any way to present division on the same line and not as a fraction? For example in Mathcad:
#2 Опубликовано: 16.12.2021 08:51:57
Is there any way to present division on the same line and not as a fraction ?
Maths Infix DIVIDE.sm (4 КиБ) скачан 83 раз(а).
sergio 16.12.2021 09:19:00
#3 Опубликовано: 16.12.2021 10:48:27
#4 Опубликовано: 16.12.2021 11:12:28
1418 сообщений из 2874 понравились пользователям.
If you don't need strictly a division symbol, you can use a multiplication
#5 Опубликовано: 17.06.2022 15:33:17
⚜ Kenny Lemens, P.E. ᵂᴵ
74 сообщений из 164 понравились пользователям.
Greetings!
...division on the same line...
It is possible to combine Davide's and Jean's solutions, but you need to pull off a few tricks:
   1) Create a custom function with (1) parameter
   2) Use the special inline division character 「÷」
   3) Declare your custom function as a 'unit' (this suppress the multiplication operation from displaying)
To create the custom function with the inline division character, copy and paste the following into your SMath Worksheet:
'÷(_denom):1/_denom
To utilize it, type in your numerator and multiply it by the custom function, where you pass the denominator into the function as the parameter.
EXAMPLE: solving for 6/2; copy and paste the following (NOTE: since I am declaring the custom function as a unit; you must include ' when calling the custom function):
6*'÷(2)=#@#
-Kenny Lemens, P.E.
sergio 17.06.2022 17:33:00, Chito 20.06.2022 03:27:00, Oscar Campo 21.06.2022 08:24:00
#6 Опубликовано: 24.06.2022 17:10:31
Greetings,
If you just need the statement to be on the same line and you want to avoid the use of exponents and custom functions, there is a native solution:
Use the function str2num(▮) and type your statement as a string:
You do have the ability to reference variables, but the use of whitespace (tab, space, newline, etc.) will corrupt the string and str2num(▮) will throw an error.
Thus this statement will work:
     str2num("(2+22)/4")=6
But this statement will throw a 'not defined' error:
     str2num("(2 + 22) / 4")=▮
Its a good day to be alive;
-Kenny Lemens, P.E.
#7 Опубликовано: 24.06.2022 19:12:53
555 сообщений из 1333 понравились пользователям.
In addition to Kenny you can remove white spaces.
Furthermore, you can define a nameless function with Ctrl+Shift+K.
It won't show a function before it, though it is a function.
By that your statement shall look as a "normal" calculation.
str2num.sm (2 КиБ) скачан 70 раз(а).
#8 Опубликовано: 24.06.2022 21:55:13
Answer is NO, Smath does not have native ÷ operator
More productive from infix algo style utilities,
for infinite in-situ command line.
infix Divide.sm (3 КиБ) скачан 72 раз(а).
#9 Опубликовано: 24.06.2022 23:12:52
Answer is YES, there are multiple ways demonstrated above. Choose what suits you most.
⚜ Kenny Lemens, P.E. ᵂᴵ 06.06.2024 03:24:00
#10 Опубликовано: 25.06.2022 14:43:46
