question of roots
question of roots - Сообщения
#1 Опубликовано: 31.08.2023 15:43:11
Prmtv
Prmtv
0 сообщений из 49 понравились пользователям.
Hello. I can't understand. Why does it turn out 4 roots or not 2? Thanks.
#2 Опубликовано: 01.09.2023 01:10:52
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi. Because that's how what might be called "scalar expansion" for sys() works. Perhaps the result you are looking for is this using vectorize()
sergio 01.09.2023 04:49:00
#3 Опубликовано: 01.09.2023 13:43:31
Prmtv
Prmtv
Thanks!
How it is better to set then an array of the data? Need to get a solution for some data (for example: values a 4, 5, 6, 7...)
Matrix didn't work either.
#4 Опубликовано: 02.09.2023 15:07:12
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi. Supposedly, vectorize operates only on matrices.
Need to get a solution for some data (for example: values a 4, 5, 6, 7...) Matrix didn't work either.
It should have worked. Do you have an example of how it didn't work?
#5 Опубликовано: 02.09.2023 18:51:05
Visit the Samples ... find zillions of examples.
#6 Опубликовано: 02.09.2023 20:35:19
You can use range() functions.
