Signals and Systems
Signals and Systems - Example of use of SMath for signals and systems analysis - Сообщения
#1 Опубликовано: 29.05.2012 16:14:49
Oscar Campo
Oscar Campo
124 сообщений из 298 понравились пользователям.
Hi, this is a snippet for numerical inverse Laplace transform. You can find time response of a system expresed in F(s) form.
enjoy
Inverse numerical Laplace
Download it here
Oscar Campo
kmihaylovich 30.05.2012 02:28:00, Davide Carpi 29.05.2012 18:13:00, Radovan Omorjan 30.05.2012 03:00:00
#2 Опубликовано: 30.05.2012 03:09:26
Hello Oscar,
Thank you for this example
By the way, I find very interesting that you defined an expression in this way an then plot it:
Function<->variable
ft() looks like a function, but it is not.
Davide Carpi 30.05.2012 07:29:00
#3 Опубликовано: 30.05.2012 07:10:43
Oscar Campo
Oscar Campo
Yes, it's something that I found accidentally. The statement ft(F(s)) appear as a function, but it's a matrix!
Oscar
#4 Опубликовано: 30.05.2012 15:18:43
Basile
Basile
8 сообщений из 172 понравились пользователям.
I tried to open it using the latest SMath.
I get an error message in the last FOR loop: "Function not defined"
Thanks,
Basile
#5 Опубликовано: 30.05.2012 15:53:17
2271 сообщений из 3736 понравились пользователям.
Группа: Super Administrator
[USERLINK]Basile[/USERLINK], you need to define a function to work with as shown in the first message.
numerical inverse Laplace Transform
Regards.
#6 Опубликовано: 31.05.2012 21:25:59
Basile
Basile
Thank you Andrey,
Basile
#7 Опубликовано: 31.05.2012 21:28:48
Basile
Basile
Oscar,
Which Numerical Inverse Laplace Transform do you use?
Any reference?
Thank you,
Basile
#8 Опубликовано: 01.06.2012 09:24:33
Oscar Campo
Oscar Campo
Hi Basile,
The method is based on work of J. Valsa and L. Brancik: Approximate Formulae for Numerical Inversion of Laplace Transforms, Int. Journal of Numerical Modelling: Electronic Networks, Devices and Fields, Vol. 11, (1998), pp. 153-166
Oscar
Davide Carpi 01.06.2012 09:32:00
#9 Опубликовано: 01.06.2012 17:29:58
Basile
Basile
Oscar,
Thank you,
Basile
#10 Опубликовано: 04.06.2012 19:47:33
Oscar Campo
Oscar Campo
Bode Diagram Revisited.
This is a function for graphing the Bode plot of a system. Please plot the magnitude and phase on a diferent graph each one, deactivate "grid" and "axis" for a better visualization of logarithmic grid.
Bode Plot
Download it here: MyBode3.sm (30 КиБ) скачан 63 раз(а).
#11 Опубликовано: 05.06.2012 15:02:37
Oscar Campo
Oscar Campo
Root Locus Snippet
This is a snippet for plotting Root Locus of a sistem. The input is the denominator of coefficients of transfer function:
rlocus
Download it here
Oscar
#12 Опубликовано: 25.08.2017 13:22:41
Leandro de Oliveira
Leandro de Oliveira
The file seems to be locked, I can't put a equation.
#13 Опубликовано: 25.08.2017 17:02:19
.. here is the Bode Plot.
Bode plot.sm (27 КиБ) скачан 215 раз(а).
Viktor 15.11.2017 19:30:00, Oscar Campo 27.08.2017 03:21:00
#14 Опубликовано: 25.08.2017 18:44:35
Open the file in SMath Studio and then go to File > Properties > File Attributes and uncheck Read-only. This attribute is required when the worksheet is designed to be a snippet.
#15 Опубликовано: 26.08.2017 09:01:49
Hi, this is a snippet for numerical inverse Laplace transform. You can find time response of a system expressed in F(s) form. enjoy
This 5 years old document does not work 6179.
Here is the Maple companion.
#16 Опубликовано: 27.08.2017 10:46:55
Oscar Campo
Oscar Campo
Only a very little detail to fix this 5 years old document: declare F(s) and change the last line on snippet:
ft( "F(s" ) = augment(t,ft)
for
ft() = augment(t,ft)
You can download the updated version from here
Davide Carpi 28.08.2017 13:28:00
#17 Опубликовано: 28.08.2017 11:01:53
... that's only several pages long of HTML code.
No work sheet. Best is to upload WS in the forum.
For "Laplace stuff", better use maple(,) as show above.
Cheers, Jean
#18 Опубликовано: 28.08.2017 11:32:53
Oscar Campo
Oscar Campo
Use "save as"
Yes, and also it’s possible use f(t)=Maxima(ilt(F(s),s,t)) but it’s interesting show how you can implement inverse Laplace of a function in SMath.
P.D. The symbolic form of f(t) obtained from ilt() it’s more “elegant” than maple version
#19 Опубликовано: 28.08.2017 13:04:34
Win 7 does not have the virtue to save HTML "save as" *.sm
OK: no work sheet => nothing to see. Tanks anyway.
Cheers, Jean
#20 Опубликовано: 28.08.2017 13:24:42
You can if you use firefox (with chrome you have to change the extension manually from .txt to .sm);
However I've edited the link, now it downloads the file, whatever is your favorite browser.
Oscar Campo 28.08.2017 14:23:00
