Signals and Systems
Signals and Systems - Example of use of SMath for signals and systems analysis - Сообщения
#41 Опубликовано: 24.09.2018 00:11:12
Hi, this is a snippet for numerical inverse Laplace transform. You can find time response of a system expressed in F(s) form.
That one was well covered, two last remarks:
1. That Smath does not trig example [1], rather in terms of exp(,)
OK, unfamiliar ... but much faster as it involves only one numerical approximation.
Whatever: it's the Maple business, from which Smath depends upon.
2. last visit [red/cyan[ is sometimes of importance as demonstrated.
InvLaplace2 Otherwise.sm (49 КиБ) скачан 79 раз(а).
#42 Опубликовано: 24.09.2018 10:21:12
... when you deal with Laplace stuff, open your school book,
that will help setup Laplace Algebra appropriately, like this:
#43 Опубликовано: 20.03.2019 07:48:00
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi. Improved version, works faster. Coefficients for the inversion are precalculated outside the inverter caller and avoiding vectorization for more compatibility of the inverter.
InvLaplace3.sm (98 КиБ) скачан 78 раз(а).
#44 Опубликовано: 20.03.2019 14:01:50
Thanks Alvaro,
Any real use for this old style inverser,
vs Maple export c/w parameters that works much faster.
Saludos ... Jean
Laplace Maple Parametric Export.sm (15 КиБ) скачан 76 раз(а).
