Method A.B. Draghilev and animation spatial mechanisms
Method A.B. Draghilev and animation spatial mechanisms - Ber7 - Сообщения
#1 Опубликовано: 26.01.2014 03:10:20
Fridel Selitsky
Fridel Selitsky
Application of the method A.B. Draghilev to the calculation of the kinematics and animation
spatial mechanisms developed prof.A.B.Ivanov, that
develops method A.B. Draghilev to solve practical problems.
Their development, with detailed explanations,
he published on the site
http://forum.exponenta.ru/viewtopic.php?t=12842
The following examples are taken from this site and transferred from Maple in the programming environment SMath Studio.
A huge thanks to Alexei Ivanov, who gave me great help in the study the method of A.B .Draghilev.
1.Explanatory example
http://ru.smath.info/forum/yaf_postst2304_Primienieniie-mietoda-A-B--Draghilieva-k-raschietu-polozhienii-i-animatsii-miekhanizmov.aspx
Davide Carpi 31.01.2014 06:17:00, Andrey Ivashov 07.05.2016 09:54:00
#2 Опубликовано: 26.01.2014 03:18:11
Fridel Selitsky
Fridel Selitsky
One end of the rod moves in the spatial
curve, the other along a circular arc.
Primer3.smz (8 КиБ) скачан 194 раз(а).
Andrey Ivashov 07.05.2016 09:54:00, Radovan Omorjan 26.01.2014 03:39:00, Davide Carpi 31.01.2014 06:17:00
#3 Опубликовано: 26.01.2014 03:21:47
Fridel Selitsky
Fridel Selitsky
Three-link spatial mechanism
PrUgol.smz (10 КиБ) скачан 126 раз(а).
Davide Carpi 31.01.2014 06:39:00, Andrey Ivashov 07.05.2016 09:54:00, Radovan Omorjan 26.01.2014 03:39:00
#4 Опубликовано: 26.01.2014 03:25:04
Fridel Selitsky
Fridel Selitsky
Spatial four-bar linkage1
Spatial four-bar linkage 2
Radovan Omorjan 26.01.2014 03:39:00, Davide Carpi 31.01.2014 06:39:00, Andrey Ivashov 07.05.2016 09:54:00
#5 Опубликовано: 26.01.2014 03:30:32
Fridel Selitsky
Fridel Selitsky
Cardan Mechanism.The axes of rotation intersect at an angle of 45 degrees
KardanHadash1.sm (89 КиБ) скачан 153 раз(а).
Andrey Ivashov 07.05.2016 09:54:00, Davide Carpi 31.01.2014 06:39:00, Radovan Omorjan 26.01.2014 03:38:00
#6 Опубликовано: 11.04.2014 02:45:17
Fridel Selitsky
Fridel Selitsky
Animation curve, which is defined implicitly
Each loop equation "cam"-an implicit function F (x, y) = 0
  Examples taken from the site
Kardeoida.smz (7 КиБ) скачан 154 раз(а).
Andrey Ivashov 07.05.2016 09:54:00, Davide Carpi 19.04.2014 09:30:00
#7 Опубликовано: 02.05.2014 17:06:20
Fridel Selitsky
Fridel Selitsky
The line of intersection of the torus and sphere(Villarceau circles)
This example is taken from an article by Дубанов А.А. :Численно-аналитическое
построение линий пересечения поверхностей методом Драгилева,2007(rus)
http://www.blagovest2002.narod.ru/2005/SurfInt/paper1/Paper1.htm
Villarceau.smz (9 КиБ) скачан 169 раз(а).
Davide Carpi 05.05.2014 03:14:00, Andrey Ivashov 07.05.2016 09:54:00
#8 Опубликовано: 12.05.2014 14:02:38
Fridel Selitsky
Fridel Selitsky
The same mechanism with spherical linkages
These linkages have the property that
every link in the system rotates about the same fixed point. Thus, trajectories of
points in each link lie on concentric spheres with this point as the center. Only the
revolute joint is compatible with this rotational movement and its axis must pass
through the fixed point.
Davide Carpi 16.05.2014 12:38:00, Andrey Ivashov 07.05.2016 09:54:00, Martin Kraska 12.05.2014 16:40:00
#9 Опубликовано: 16.05.2014 07:03:17
I can't see the last image (neither in the russian side of the forum)
#10 Опубликовано: 16.05.2014 11:01:47
Fridel Selitsky
Fridel Selitsky
Link to the file and image:
https://smath.com/wiki/GetFile.aspx?File=Guk.gif
KardanHadash.smz (11 КиБ) скачан 115 раз(а).
Davide Carpi 16.05.2014 12:38:00, Andrey Ivashov 07.05.2016 09:53:00
#11 Опубликовано: 02.06.2014 11:36:46
Fridel Selitsky
Fridel Selitsky
Ring instead of cross-piece
KardanHadash3.smz (13 КиБ) скачан 140 раз(а).
Andrey Ivashov 07.05.2016 09:53:00, Davide Carpi 19.07.2015 16:45:00
#12 Опубликовано: 18.07.2015 10:45:48
Fridel Selitsky
Fridel Selitsky
3-PRS Parallel Manipulator
Tripod2s.smz (15 КиБ) скачан 123 раз(а).
#13 Опубликовано: 30.08.2015 17:51:05
Fridel Selitsky
Fridel Selitsky
The Delta Parallel Robot
Kinematic scheme and dimensions are taken from the book
R.L. Williams II, “The Delta Parallel Robot: Kinematics Solutions”, Internet Publication,
April 2015.
Файл не найден. Файл не найден.
Delta.pdf (542 КиБ) скачан 298 раз(а).
Andrey Ivashov 01.09.2015 19:03:00, Davide Carpi 31.08.2015 18:12:00
#14 Опубликовано: 14.09.2015 05:37:56
Fridel Selitsky
Fridel Selitsky
RSCRmod.sm (106 КиБ) скачан 100 раз(а).The RSCR spatial mechanism.
The calculation is borrowed from the publication of Alexey Ivanov
http://www.mapleprimes.com/posts/201080-RSCR-Spatial-Mechanism
A case where the axis of rotation are perpendicular
RSCRmechanism.smz (15 КиБ) скачан 126 раз(а).
Davide Carpi 14.09.2015 06:23:00, Andrey Ivashov 07.05.2016 09:53:00
#15 Опубликовано: 23.10.2015 17:19:26
Fridel Selitsky
Fridel Selitsky
Again The Delta Parallel Robot.Winding onto a cylindrical mandrel
Delta2.smz (601 КиБ) скачан 166 раз(а).
Davide Carpi 23.10.2015 18:56:00, Andrey Ivashov 07.05.2016 09:53:00
#16 Опубликовано: 27.10.2015 12:26:45
Fridel Selitsky
Fridel Selitsky
Delta3.smz (600 КиБ) скачан 132 раз(а).Version for conical spiral
Davide Carpi 21.11.2015 13:42:00, Andrey Ivashov 07.05.2016 09:52:00
#17 Опубликовано: 21.11.2015 08:37:36
Fridel Selitsky
Fridel Selitsky
Delta0C.smz (321 КиБ) скачан 162 раз(а).In the above animation three links that support the lower platform is a simplified and
presented in the form of red rods. Actually used parallelograms (pantographs), where top and
bottom mounted universal (cardan) joints. Each universal joint implemented using Three
revolute joints . The axis of the middle joints lies in the plane of the parallelogram, and
axis external joints perpendicular to this plane. Animation of this design is shown below.
#18 Опубликовано: 07.05.2016 07:55:01
Fridel Selitsky
Fridel Selitsky
Graf.smz (144 КиБ) скачан 105 раз(а).Spatial (spherical) Cam
The idea is taken from here
http://www.mapleprimes.com/questions/209853-Is-It-Possible-To-Get-This-In-MapleSim-#comment225311
Andrey Ivashov 07.05.2016 09:52:00, Davide Carpi 09.05.2016 05:31:00
#19 Опубликовано: 30.07.2016 07:23:41
Fridel Selitsky
Fridel Selitsky
A mechanisms similar to slider crank mechanism
These mechanisms are shown Alexey B. Ivanov on the website
https://vk.com/away.php?to=http%3A%2F%2Fwww.mapleprimes.com%2Fposts%2F204684-Lever-Mechanisms
Davide Carpi 01.08.2016 18:52:00
#20 Опубликовано: 02.08.2016 15:22:02
Thanks Ber7 for your repost/new animations. Some don't work in Smath 5346,
so what. Animation is a very nice feature from Smath.
Rotate XY.sm (474 КиБ) скачан 115 раз(а).
