Vibrations of membranes
Vibrations of membranes - Сообщения
#1 Опубликовано: 28.12.2017 17:10:57
Fridel Selitsky
Fridel Selitsky
Vibrations of a circular membrane.The axisymmetric case
Solution are described with the help of Bessel functions .
https://en.wikipedia.org/wiki/Vibrations_of_a_circular_membrane
Bessel'2.sm (29 КиБ) скачан 172 раз(а).
Andrey Ivashov 24.01.2018 16:38:00, Davide Carpi 29.12.2017 12:53:00
#2 Опубликовано: 31.12.2017 13:46:43
Tanks Ber7: saved in your named file.
#3 Опубликовано: 06.01.2018 05:14:01
Fridel Selitsky
Fridel Selitsky
Vibrations of a rectangular membrane
Calculation formulas are taken from the book:S.Timoshenko,
Vibration Problems In Engineering
MemPl.sm (14 КиБ) скачан 173 раз(а).
Davide Carpi 06.01.2018 06:21:00, Andrey Ivashov 24.01.2018 16:37:00, frapuano 06.01.2018 08:26:00
#4 Опубликовано: 09.01.2018 18:03:52
Fridel Selitsky
Fridel Selitsky
Vibrations of a circular membrane.The general case
Bessel'5.sm (22 КиБ) скачан 122 раз(а).
Andrey Ivashov 24.01.2018 16:37:00, Davide Carpi 19.01.2018 20:26:00
#5 Опубликовано: 19.01.2018 12:37:31
Fridel Selitsky
Fridel Selitsky
Deflection of simply supported equilateral triangular plate
The plate rests on a frame in the form of an equilateral triangle.
The triangular part of the plate is loaded uniformly distributed
load. The equation of the surface of deflections of a triangular plate is taken
from the book of S.P.Timoshenko.Timoshenko S.P., Woinowsky-Krieger S. Theory of plates and shells. New York, NY: McGraw-Hill; 1959.
triangular plate.sm (12 КиБ) скачан 118 раз(а).
Andrey Ivashov 24.01.2018 16:37:00, Davide Carpi 19.01.2018 20:26:00, NDTM Amarasekera 19.01.2018 22:43:00
#6 Опубликовано: 19.01.2018 14:47:19
Thanks Ber7 for that one and the other one few days ago.
#7 Опубликовано: 24.01.2018 16:02:51
Fridel Selitsky
Fridel Selitsky
I tried to use the plugin Maxima
PlateMaxima.sm (143 КиБ) скачан 128 раз(а).
Andrey Ivashov 24.01.2018 16:37:00, frapuano 24.01.2018 19:43:00
#8 Опубликовано: 25.01.2018 23:52:49
Thanks Ber7, I love those 3D, though it will never beat Mathcad 8... 11.
On my own, I published several times more than the entire Mathcad Community.
I don't miss them in Smath 6179, why ? purely useless for the Engineer.
They are just for the Gallery [Tom G. would say Peanut Gallery].
We are just waiting for a stable Smath version delivered with Maxima plugin
and more of the possible plugins. Scilab looks far superior to Maxima ?
#9 Опубликовано: 29.01.2018 06:24:36
Fridel Selitsky
Fridel Selitsky
Deflection of a Circular Plate.Plate contains rigid
inclusion of radius b and loaded at the Center
(Timoshenko,S.and Woinowsky-Krieger, S.,Theory of plates and shells, 1959)
Inclusion.sm (32 КиБ) скачан 117 раз(а).
Davide Carpi 29.01.2018 07:29:00
#10 Опубликовано: 26.01.2019 22:30:30
Laurent Fournier
Laurent Fournier
9 сообщений из 66 понравились пользователям.
Hello Beer7, is this vibration of a rectangular membrane equivalent to the deflection of a simply supported, uniformly loaded, rectangular plate? (leaving aside the physical parameters like plate thickness, Young's modulus etc.) I am only interested in the curvature on various locations on the surface, not in absolute values (max deflection can be calculated using simple civil engineering formulaes).
Thanks,
Laurent
#11 Опубликовано: 27.01.2019 00:30:46
Vibrations of a circular membrane.The axis symmetric case
Solutions are described with the help of Bessel functions .
Thanks Ber7, works great. Beautiful work.
mwbesselj(0,x) is ~ 4 times faster 15 decimals
Hart JZERO 5852 is 23 decimals up to ± 8.
Bessel JY.sm (75 КиБ) скачан 96 раз(а).
#12 Опубликовано: 27.01.2019 01:55:42
What happened, your previous post is gone with the wind ???
Try this, so much faster !
Bessel mwbesselj Membrane Ber7 [20190126].sm (31 КиБ) скачан 113 раз(а).
#13 Опубликовано: 03.01.2021 05:47:58
Fridel Selitsky
Fridel Selitsky
Vibrations of a triangular membrane
Calculation formulas are taken from thearticle:
http://ivdon.ru/uploads/article/pdf/IVD_44__1_Chernyshov.pdf_30f490557a.pdf
Vibration triangular membrane.sm (319 КиБ) скачан 81 раз(а).
Alvaro Diaz Falconi 04.01.2021 12:30:00
#14 Опубликовано: 03.01.2021 11:28:34
Thanks, works fine after doctoring CreateMesh.
#15 Опубликовано: 03.01.2021 13:23:53
Fridel Selitsky
Fridel Selitsky
Vibrations of a triangular membrane(Maxima)
TriangularMembrane Maxima.sm (279 КиБ) скачан 84 раз(а).
