I run the portable version at work to check and do calculations since I cannot install software. I cannot find the symbolic parameters under version 0.95 build 4594.
I am also having a problem with functions ... where I define a function on top and I am required to copy and past that same function further down
I am writing a guide and need to be able to algebraicly manipulate equations ( in MathCAD, under the symbolics library, there is a solve where you plug in the variable to solve for)
e.g. y=x+c -> c=y-x is this possible in SMath? Mathcad had "symbolic Solve" and I can not find a similar feature in SMath ... YET! This feature was requested several years ago. http://en.smath.info/forum/default.aspx?g=posts&t=446
See attached
Equation 2 needs to be equation 1 for the functions to work. Other items still are open
Pipe Insulation.smz (28 КиБ) скачан 51 раз(а).
