Find y(x)
Find y(x) - Сообщения
#1 Опубликовано: 26.09.2022 18:13:07
Parlepanpindipon
Parlepanpindipon
0 сообщений из 9 понравились пользователям.
Hello everyone, I have such a task here, you need to find y (x) for each value of x in the range from 1.2 to 2.4 with a step of 0.2.
X I managed to display and see the result. However, when writing the formula y(x) and trying to display y(x), it gives an error. help me please
Plus I can't figure out how to write sin^2(x) in order to have a formula...
#2 Опубликовано: 26.09.2022 18:17:37
Parlepanpindipon
Parlepanpindipon
#3 Опубликовано: 26.09.2022 18:21:06
Parlepanpindipon
Parlepanpindipon
And the result should be displayed as x = {}
#4 Опубликовано: 26.09.2022 18:37:29
churichuro
churichuro
28 сообщений из 79 понравились пользователям.
#5 Опубликовано: 26.09.2022 18:57:35
Seems to be a very old version of SMath Studio (display of ranges, round matrix brackets). May well be that the vectorize function isn't available yet in that version. You might consider upgrading or you have to use an explicit loop with for or while.
#6 Опубликовано: 26.09.2022 19:16:16
Let's visualize what Martin has perfectly described.
#7 Опубликовано: 27.09.2022 02:02:16
Parlepanpindipon
Parlepanpindipon
Oh, I'm sorry, could you tell me how to make a vector over y(x)?
#8 Опубликовано: 27.09.2022 02:56:56
Parlepanpindipon
Parlepanpindipon
Ok, I tried to do it through the "for" loop, but it didn't work out very well for me, can you tell me how to do it?
#9 Опубликовано: 27.09.2022 03:55:50
you can either click Vectorize button at right tool window, or directly write vectorize as it is a function.
You can see the button in picture I have uploaded at post #6.
#10 Опубликовано: 27.09.2022 05:20:48
Parlepanpindipon
Parlepanpindipon
by clicking on vectorize I have the followingizobrazhenie_2022-09-27_112045189.png
#11 Опубликовано: 27.09.2022 05:35:46
That's the dinamic assistance when you write directly vectorize
Here is the vectorize button as shown by overlord in post #6
As stated by mkraska, it is possible that you are using an old version of the program that doesn't have that function (in that case you have to use a loop to evaluate the function for each n-th value of x)
#12 Опубликовано: 27.09.2022 06:00:48
Parlepanpindipon
Parlepanpindipon
As stated by mkraska, it is possible that you might using an old version of the program that doesn't have that function (in that case you have to use a loop to evaluate the function for each n-th value of x)
ok, I understand, but when I write vectorization, there is no such component, most likely there is simply no plugin or am I mistaken?
#13 Опубликовано: 27.09.2022 06:08:12
Parlepanpindipon
Parlepanpindipon
#14 Опубликовано: 27.09.2022 06:24:19
Therefore you are in this case:
You have to update to a new version if you want to take advantage of vectorize, otherwise you have to use a loop from the programming palette (for or while); here you have a couple of ways
loops.sm (7 КиБ) скачан 43 раз(а).
BTW vectorize() is available in stable releases since SS 0.98.5935 (April 2016); square brackets in ranges are more recent, since SS 0.98.6593 (January 2018)
#15 Опубликовано: 27.09.2022 08:02:43
sin²(x) is silent code for purpose, often replied by maple
You have to code it as exemplified.
Maths sin2(x) plot.sm (6 КиБ) скачан 48 раз(а).
#16 Опубликовано: 27.09.2022 08:32:39
... Previous Smath document has been removed from Smath Community.
#17 Опубликовано: 27.09.2022 08:36:48
I missed this part, sorry. Simply type this sequence (the highlighted content):
sin( > x > keyboard right arrow > ^ > 2
tricks like those shown by Jean Jiraud above are useful if you want to disply the content in a different way or in other cases beyond a beginner level needs (in other words, there is no need to overcomplicate the things here).
Here you have your example with sin^2(x) and probably the more compact way to make it working in your Smath Studio version.
Parlepanpindipon_sin2(x).sm (5 КиБ) скачан 50 раз(а).
#18 Опубликовано: 27.09.2022 10:19:15
Parlepanpindipon
Parlepanpindipon
Thx, very much
#19 Опубликовано: 27.09.2022 12:58:16
... no tricks in there, just productive project at will,
that you didn't download, i.e: not helping yourself !
#20 Опубликовано: 27.09.2022 19:34:52
