1 страниц (2 вхождений)
Array position - another approach - Сообщения
#1 Опубликовано: 07.09.2023 12:34:24
I remember there were some useful posts to find the positions in an array
satisfying defined conditions.
Another approach is attached.
Array_Pos2.sm (15 КиБ) скачан 83 раз(а).
Oscar Campo 07.09.2023 16:57:00, oscar mauricio 07.04.2024 10:46:00, francesco rapuano 08.01.2025 23:06:00, sergio 07.09.2023 12:38:00, Alvaro Diaz Falconi 08.09.2023 15:06:00
#2 Опубликовано: 08.09.2023 14:59:13
To expand on this concept further, I generally avoid using augment/stack functions with vectors of indeterminate size. The reason being that there is generally quite a bit of overhead in using those functions when it comes to execution time. I propose an alternative method shown here. Firstly we perform the test on the input matrix to determine the size of the result vector and location of results in input matrix. Then we instantiate the result vector and fill it in. To demonstrate the difference in execution I've also created a 100x100 input vector and timed the execution of both algorithms. The execution time difference becomes more apparent the larger the input matrix becomes.
Array_Pos2.pdf (137 КиБ) скачан 67 раз(а).
Array_Pos2.sm (44 КиБ) скачан 87 раз(а).
francesco rapuano 08.01.2025 23:08:00, Alvaro Diaz Falconi 08.09.2023 15:07:00, NDTM Amarasekera 08.09.2023 16:37:00, sergio 09.09.2023 05:57:00
Новые сообщения
Нет новых сообщений
