CoolProp Wrapper
CoolProp Wrapper - Pure and pseudo-pure fluid equations of state and transport properties for 122 components - Сообщения
#61 Опубликовано: 21.04.2023 15:17:35
1402 сообщений из 1708 понравились пользователям.
How can I get properties of mixtures e.g
CoolProp_Props("Dmass","T",273+100,"P",101.3*10^3,"Helium[0.5]&Xenon[0.5]"
ref: http://www.coolprop.org/fluid_properties/Mixtures.html
This can't be done directly in the current version of the plugin. It is not clear how to call the apply_simple_mixing_rule() function from the library, it can't be imported as it is not in the export table.
Click to enlarge
Click to enlarge
maple-python-coolprop.sm (6 КиБ) скачан 79 раз(а).
maple-python-coolprop.pdf (19 КиБ) скачан 86 раз(а).
Click to enlarge
maple-python-coolprop-2.sm (5 КиБ) скачан 71 раз(а).
#62 Опубликовано: 22.04.2023 05:00:09
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi. Notice that Refprop from NIST can't handle He/Xe mixing either. At least version 9.
On the other hand, maple doesn't seem to implement the procedure that Viacheslav points out either, as can be seen in the online documentation for the latest version.
However, very good values can be obtained using Coolprop in SMath and some basic stoichiometry.
Mixing gases.sm (19 КиБ) скачан 77 раз(а).
Mixing gases.pdf (67 КиБ) скачан 92 раз(а).
#63 Опубликовано: 22.04.2023 05:34:44
More simple
Click to enlarge Click to enlarge Click to enlarge
maple-python-coolprop-3.sm (10 КиБ) скачан 79 раз(а).
maple-python-coolprop-3.1.sm (10 КиБ) скачан 63 раз(а).
maple-python-coolprop-3.2.sm (10 КиБ) скачан 81 раз(а).
Alvaro Diaz Falconi 22.04.2023 09:32:00
#64 Опубликовано: 27.04.2023 03:09:34
Now you can write like this
maple-python-coolprop-3.3.sm (9 КиБ) скачан 74 раз(а).
#65 Опубликовано: 28.04.2023 07:39:13
Or like this
maple-python-coolprop-3.4.sm (10 КиБ) скачан 76 раз(а).
maple-python-coolprop-3.5.sm (10 КиБ) скачан 79 раз(а).
#66 Опубликовано: 29.04.2023 15:33:10
Click to enlarge
maple-python-coolprop-3.6.sm (9 КиБ) скачан 87 раз(а).
#67 Опубликовано: 29.04.2023 22:07:03
churichuro
churichuro
28 сообщений из 79 понравились пользователям.
is fantastic!
this no work the first time but after I play with the another examples this work, very well
thank you!
#68 Опубликовано: 04.05.2023 10:29:17
Without "pyfile" (inline multiline script). The script should be without comments.
Space padding is necessary here so that inside the script, when a large string is divided into parts, the line break character itself is not divided ( '\n' -> '\ n' ).
maple-python-coolprop-3.7.sm (9 КиБ) скачан 81 раз(а).
maple-python-coolprop-3.8.sm (6 КиБ) скачан 77 раз(а).
maple-python-coolprop-3.9.sm (8 КиБ) скачан 88 раз(а).
#69 Опубликовано: 30.07.2023 08:12:32
usamakhan
usamakhan
3 сообщений из 75 понравились пользователям.
Uni, can you please help me how to add python into SMATH, I have python already in system [WinPython 3.9] How I link it up with Smath?
I have working CoolProp
#70 Опубликовано: 30.07.2023 13:33:42
usamakhan
usamakhan
Jean, can you help me how do integrate python in my Smath? I event tried environmental variables under Win10 but didn't work
#71 Опубликовано: 31.07.2023 03:45:32
You should use a double slash for the full path.
In this case, you need to check whether python is available from the command line. If not, it means that the paths are specified incorrectly.
#72 Опубликовано: 02.08.2023 19:17:11
usamakhan
usamakhan
uni, thanks a lot
Can you tell me what is this block you used after python sub-section [i.e with the square bracket & holding script conetnts]
Additionally Razonar sample here is also very intuitive while calculating mixing values
https://en.smath.com/forum/yaf_postsm82120_Understanding-Redlich-Kwong-equation-of-state.aspx#post82120
#73 Опубликовано: 03.08.2023 03:06:16
uni, thanks a lot
Mathcad Block from the Mathcad Toolbox plugin and just Text inside it for the script.
#74 Опубликовано: 04.08.2023 15:23:07
usamakhan
usamakhan
uni, so it means the text inside the block is not automatically generated. Can you please explain the construct
On second note you were correct, I fixed my environment variable under windows %python% now works
#75 Опубликовано: 08.08.2023 02:01:18
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Phase diagrams with CoolProps.
Click to enlarge
PhaseDiagram.sm (39 КиБ) скачан 84 раз(а).
Davide Carpi 08.08.2023 02:10:00
#76 Опубликовано: 09.08.2023 03:47:50
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Psychrometric Chart with CoolProps. 'Simplified' version (more readable): Enthalpy lines overlap web bulb temperature lines.
Click to enlarge
PsychrometricChart.sm (125 КиБ) скачан 83 раз(а).
#77 Опубликовано: 21.08.2023 17:39:50
usamakhan
usamakhan
I think I have found some problems while using plugin to get phase properties as discussed here: http://www.coolprop.org/coolprop/HighLevelAPI.html#imposing-the-phase-optional
First when using "P|phase_gas" it doesn't accept units & T,P values have to be directly written in SI equivalent
Second there is a value discrepancy when using "P" & "P|phase_gas" for a fluid that exists only in gas phase at that T,P
#78 Опубликовано: 16.04.2024 03:55:20
It seems that multiple instances of SMath can't use the plugin at the same time.
How to reproduce:
1. Open SMath and access any Coolprop function
2. Open another SMath instance: You get an error message
