CoolProp Wrapper - Pure and pseudo-pure fluid equations of state and transport properties for 122 components - Сообщения
Wroteis it possible to run it on ubuntu 17.10 using mono?, I can't get it to work, when I try to evaluate "CoolProp_get_global_param_string("version")" I just get a little yellow message under the command that reads "CoolProp_x64", or do I need to compile the coolprop binaries ins some specific folder or is it a standalone plugin-extension?
The plug-in it's composed by 3 files, the SMath wrapper plus 2 coolprop libraries (one for x86 systems, the other for x64 ones); according to this issue, it should be possible if you compile the coolprop library (the core) in your machine and then you replace the one shared within this plugin.
Changes: refactored.
WroteUpdated.
I just started playing with this tool, so please be patient with my ignorance.
Updated to what? The version on my system is 6.1.0; however, the CoolProp website is on 6.4.1
I've also noticed that some of the description paramater names fail.
In addition, off of other threads, there appears to be "commands" that are no longer valid. An example would be FProp here.. Please advise.
I'm still searching for information as to what the other functions do (e.g. CoolProp_get_param_index)
WroteThe plug-in it's composed by 3 files, the SMath wrapper plus 2 coolprop libraries (one for x86 systems, the other for x64 ones)
The plugin consists of two parts: a wrapper and a library. I didn't change the library, I just updated the wrapper source code.
It is possible to update the library version. I don't know where the documentation is and how the set of parameters changes depending on the version.
WroteWroteThe plug-in it's composed by 3 files, the SMath wrapper plus 2 coolprop libraries (one for x86 systems, the other for x64 ones)
What is the correct location for the wrapper? From the 1st post, these are invalid
ЦитатаOfficial SMath wrapper (you have to build it by yourself, instructions in his documentation)
- repository: https://github.com/CoolProp/CoolProp/tree/master/wrappers/SMath;
- documentation: http://www.coolprop.org/coolprop/wrappers/SMath/;
I may take a crack at compiling the newer version
WroteI can update the whole plugin including the library if you need.
That would be appreciated. Version 6.1.0 is from 2016 and 6.4.1 is Aug. 2020.
On another post (by you), there seemed to be a relation with MathCad. In Sourceforge, MathCad and Prime are compiled by the CoolProp group. Could those files be used so we can just update the few dll files?
https://sourceforge.net/projects/coolprop/files/CoolProp/6.4.1/
https://sourceforge.net/projects/coolprop/files/CoolProp/nightly/
WroteOn another post (by you), there seemed to be a relation with MathCad. In Sourceforge, MathCad and Prime are compiled by the CoolProp group. Could those files be used so we can just update the few dll files?
Yes, you can use these libraries, but this is not a good idea. Better to use direct way.
Initialize failed for backend: "?", fluid: "INCOMP::MEG-50%" fractions "[1.0000000 ]"; error: key [INCOMP::MEG-50%] was not found in string_to_index_map in JSONFluidLibrary : PropsSI("D","T",288.15,"P",101325.3532,"INCOMP::MEG-50%" )
This call was working March of this year. Any suggestions on what may be causing this issue?
Using:
CoolProp Wrapper Plugin 6.1.7713.14622
Smath Version: Smath Studio Desktop 64-bit, 0.99 (build: 7822)
CoolProp Version: CoolProp_v6.4.1.0
Windows 10 Pro 64-bit
Issue: CoolProp Plugin functions not recognized by Smath
What I've tried:
- Adding/removing CoolProp Plugin (through the Extensions Manager in Smath Studio Desktop)
- re-installed SMATH Studio; deleting plugin folder after uninstall
- Re-installing CoolProp
Could you please provide guidance on what may be causing this issue?
CoolPropWrapper-6.4.7910.17946.zip (2 МиБ) скачан 67 раз(а).
WroteThe reason for this behavior has not yet been clarified. Use this library for now, replacing the original one (\extensions\plugins\ca92ef03-c7da-4888-98ad-528482733e2f\x.x.x.x\).
I've downloaded the .dll you provided and placed it in the plugins folder.
I get the following error message when I open Smath:
%appdata%\SMath\extensions\plugins\ca92ef03-c7da-4888-98ad-528482733e2f\6.4.7910.14793\
The last numbers may vary. This is the plugin folder. After replacing the file (CoolPropWrapper.dll), everything should work.
Новые сообщения
Нет новых сообщений
