1 страниц (11 вхождений)
Matrix Data - Getting the wrong information - Сообщения
#1 Опубликовано: 12.04.2018 16:33:22
I need the information for 1 pipe diameter smaller ... sigh, I hate programming
PipeVel.sm (10 КиБ) скачан 66 раз(а).
#2 Опубликовано: 12.04.2018 18:57:52
#3 Опубликовано: 12.04.2018 20:43:16
WroteI need the information for 1 pipe diameter smaller ... sigh,
I hate programming
Model your pipe from inspired working document.
Inst_Colebrook Pipe Data.sm (59 КиБ) скачан 75 раз(а).
#5 Опубликовано: 13.04.2018 17:18:30
Muchas gracias Carlos. Lo que no podia ver es la indice else --> index.j:1 Handaba pensando en algo similar para retener el numro viejo, pero nada se me vino a la mente.
Ruben
Ruben
#6 Опубликовано: 13.04.2018 17:25:39
No hay de que Ruben. Recibe un cordial saludo.
Carlos
Carlos
#7 Опубликовано: 13.04.2018 22:01:39
Ruben: A slightly more complicated algorithm, which supports several speeds and several flows.
PipeVel_CBG_R1.sm (14 КиБ) скачан 62 раз(а).
Carlos
Carlos
#8 Опубликовано: 14.04.2018 10:07:09
Interesting. I was looking at modifying your other code ... this is better inspiration.
I'm looking at sizing pipe at low flow, then calculate velocity, fixed pipe dia, at a higher flow. With your original code, I set this up in two steps to look at VFD driven system.
#9 Опубликовано: 14.04.2018 14:58:53
WroteI'm looking at sizing pipe at low flow, then calculate velocity, fixed pipe ID, at a higher flow.
TW, Tanks Carlos ... lovely code.
Elsid, about your request:
That's what "Colebrook Pipe Data" [post 3] does.
1. For industrial projects, we measure MassFlow, not volumetric
... volumetric is for simple/primitive municipal water work.
2. "Colebrook Pipe Data" in based on 100 m, pipe length.
3. Pipe sizing is like valve sizing: trial/error,
... mostly wrt "Nominal" design conditions.
4. Convert your input data from SI to US
5. post convert back from SI to US.
#10 Опубликовано: 15.04.2018 10:17:34
Jean,
I tend to deal in "volumetric is for simple/primitive municipal water work." And hydronic systems.
#11 Опубликовано: 15.04.2018 10:52:33
WroteJean,
Hydronics is the use of water as the heat-transfer medium in heating and cooling systems. A hydronic piping system is used to circulate chilled or hot water with the connections between the piping and the terminal units made in a series loop.
Whatever "Hydronic" is hot/cold, the water has properties wrt to MASS.
Reverse Engineering in your proposal does not solve project not understood from the onset.
Новые сообщения
Нет новых сообщений
