Stable: SMath Studio 1.0.8253 (06 August 2022)
Stable: SMath Studio 1.0.8253 (06 August 2022) - Сообщения
#1 Опубликовано: 05.08.2022 21:23:29
2270 сообщений из 3734 понравились пользователям.
Группа: Super Administrator
Changes introduced in current build 1.0.8253
Улучшения
  • Doubleclick on the unit placeholder (at right-hand side of the calculation result) opens Insert Unit dialog with suggested dimension now;
  • Go to Definition command opens Insert Unit dialog with unit/dimension details when applicable now;
  • Units dialog improved to display unit definition;
  • Approximately not equal operator implemented.
Исправления
  • Closing of the Worksheet when file saving is required fixed;
  • Observations happens in some cases with Approximately Equal operator when comparing small numbers fixed;
  • Command line functionality restored.
Разное
  • Window with empty Worksheet is now automatically closed on open a file (no empty documents are generated now);
  • Refactoring.
Download
SMathStudioAndroid.1_0_8253.arm64-v8a.apk (12 МиБ) скачан 2925 раз(а).
SMathStudioAndroid.1_0_8253.armeabi-v7a.apk (14 МиБ) скачан 2335 раз(а).
SMathStudioAndroid.1_0_8253.x86_64.apk (13 МиБ) скачан 2177 раз(а).
SMathStudioAndroid.1_0_8253.x86.apk (13 МиБ) скачан 2111 раз(а).
SMathStudioDesktop.1_0_8253.Mono.tar.gz (1 МиБ) скачан 14077 раз(а).
SMathStudioDesktop.1_0_8253.Setup.msi (3 МиБ) скачан 56994 раз(а).
SMathStudioDesktop.1_0_8253.x86_64.astra-orel.glibc2.24.AppImage (10 МиБ) скачан 2344 раз(а).
SMathStudioDesktop.1_0_8253.x86_64.ubuntu-22_04.glibc2.35.AppImage (12 МиБ) скачан 2722 раз(а).
System requirements
  • Desktop (Windows):
  • Desktop (Linux):
Interface languages (37 languages)
  • [ARA] Arabic / العربي
  • [BEL] Belarusian / Беларуская
  • [BUL] Bulgarian / Български
  • [CAT] Catalan / Català
  • [CZE] Czech / Čeština
  • [DAN] Danish / Dansk
  • [DUT] Dutch / Nederlands
  • [ENG] English / English
  • [FAS] Persian / فارسی
  • [FIN] Finnish / Suomi
  • [FRE] French / Français
  • [GER] German / Deutsch
  • [GRE] Greek / Ελληνικά
  • [HEB] Hebrew / עברית
  • [HUN] Hungarian / Magyar
  • [IND] Indonesian / Bahasa Indonesia
  • [ITA] Italian / Italiano
  • [JPN] Japanese / 日本語
  • [KOR] Korean / 한국어
  • [LAV] Latvian / Latviešu
  • [LTH] Lithuanian / Lietuvių
  • [NOR] Norwegian / Norsk
  • [POL] Polish / Polski
  • [RON] Romanian / Română
  • [RUS] Russian / Русский
  • [SCC] Serbian (Latin) / Srpski
  • [SCR] Croatian / Hrvatski
  • [SLK] Slovak / Slovenčina
  • [SPA] Spanish / Español
  • [SRP] Serbian (Cyrillic) / Српски
  • [SWE] Swedish / Svenska
  • [TUR] Turkish / Türkçe
  • [UKR] Ukrainian / Українська
Tutorial
  • SMathPrimer.pdf (Date: 11.11.2011. File size: 2.06MB) - to open in Adobe Acrobat Reader
Other files
SMath Studio icons () of all available sizes (16x16, 24x24, 32x32, 48x48, 64x64, 96x96, 128x128, 256x256) in PNG format.
8 пользователям понравился этот пост
Вячеслав Мезенцев 05.08.2022 23:48:00, João Felipe Seráfico Melo 06.08.2022 00:04:00, sergio 06.08.2022 05:42:00, Davide Carpi 06.08.2022 06:06:00, NDTM Amarasekera 06.08.2022 06:51:00, Laurent Fournier 06.08.2022 07:54:00, Mark R Harris 10.08.2022 01:52:00, IVR 10.09.2022 13:14:00
#2 Опубликовано: 09.08.2022 11:26:03
Ruben Sidranski
Ruben Sidranski
17 сообщений из 463 понравились пользователям.
Thank you. I haven't been here much, but always support and appreciate the work that has gone into this project.
So, doing a clean OS install and I checked to confirm the latest version. The portable version of 1.8151 did NOT let me know that there was an update available...
#3 Опубликовано: 09.08.2022 12:46:23
The "don't check for updates" checkbox is unchecked?
#4 Опубликовано: 09.08.2022 16:51:30
Ruben Sidranski
Ruben Sidranski
Davide,
That is correct. This is for the portable version. Looks like Andrey posted 4 days ago and I was the first comment ... maybe others didn't get the update pop-up message on their full install as well.
Time to reload my OSesesesese.
#5 Опубликовано: 12.08.2022 04:25:06
kadpeter
kadpeter
0 сообщений из 10 понравились пользователям.
Привет Андрей!
Я хотел бы использовать в расчётах момент, но до сих пор не нашёл. Положи пожалуйста в SMath (изгибающий момент, вращающий момент, крутящий момент - единицы 'Nm' и 'kNm').
Я нашёл ещё ошибку в венгерском языке, 'Ellenálás' не правильно, надо писать 'Ellenállás' (по-русски сопротивление).
Kaderász Péter
#6 Опубликовано: 12.08.2022 04:59:16
Пока момента в списке единиц нет, можете использовать составленные единицы: 'N*'m.
Мне также неудобно что всегда нужно ручно изменить J на. 'N*'m. Но так и будет при наличии 'Nm т.к. это вряд ли хорошая единица по умольчанию для всяких величин размерности сила на длину. Скорее вчего для большинства имеется в виду работа или энергия.
#7 Опубликовано: 12.08.2022 09:31:11
kadpeter
kadpeter
Привет Мартин!
Я уже несколько лет пишу в первый ряд на невидную область дефиницию момента:
Потом я могу использовать Nm.
Kaderász Péter
#8 Опубликовано: 31.08.2022 14:01:51
Alexander O. Melnik
Alexander O. Melnik
127 сообщений из 494 понравились пользователям.
Hello Andrey, to let you know the below was not addressed in 1.0.8253:
Updating from 1.0.8151 to 1.0.8238 broke background printing of smath document. I used to be able to copy paste the file onto one note page (for collaboration), right click on it and "insert as printout" (see screenshot). This functionality broke down with switch to 1.0.8238. I will stay at 1.0.8151 for now.
Cheers
Sasha
