Deleting Rows an Columns
Deleting Rows an Columns - Matrice Handling - Сообщения
#1 Опубликовано: 30.05.2021 22:31:23
Some functions for row and column deletion.
For row and column functions accepts horizontal and vertical vectors, range(2) and range(3), numbers.
No need to convert anything during input, and exceeding and subceeding values not be removed.
delete_rowcol.sm (21 КиБ) скачан 68 раз(а). (old method)
delete_rowcol.sm (15 КиБ) скачан 73 раз(а). (new and faster method)
sergio 31.05.2021 05:16:00
#2 Опубликовано: 31.05.2021 08:01:39
Otherwise useful ... you delete what you don't select.
sergio 31.05.2021 08:16:00
#3 Опубликовано: 01.06.2021 00:23:20
NDTM Amarasekera
NDTM Amarasekera
Alternate program. Very fast on large matrix.
Jean's program very helpful. Thank you Jean
New_Matrix_Delete [col_row].sm (24 КиБ) скачан 73 раз(а).
overlord 03.06.2021 21:45:00, sergio 01.06.2021 04:28:00
#4 Опубликовано: 01.06.2021 11:30:22
I tried your solution and found out it is faster with single row or single column removal. Good job.
And also found out transpose method is way much slower if I use ranges or matrices for input.
That method is not fast enough and not a good method when you use vectors of columns or rows for removal.
So I have combined your solution with mine, a fast and feature-full method is born.
New file is added in first post.
NDTM Amarasekera 01.06.2021 13:29:00
#5 Опубликовано: 01.06.2021 12:52:21
From square/rectangular matrix algo style do all at will.
1. delete cols & rows in any shuffled ways.
2. conserve selected rows deleted of 'j'.
3. conserve selected cols deleted of 'j'.
Hopefully, no red in your SS version !
Thanks, be good ... Jean.
Utilities Matrix Minor [col_row] ADVANCED OTHERWISE Copy.sm (21 КиБ) скачан 64 раз(а).
#6 Опубликовано: 01.06.2021 13:28:36
NDTM Amarasekera
NDTM Amarasekera
Yes it works fast. It is a smart code with added features.
Thank you.
#7 Опубликовано: 02.06.2021 15:34:35
NDTM Amarasekera
NDTM Amarasekera
A revised version, to delete multiple non-adjacent columns.
Faster on large matrix than my last example in post #3.
New_Matrix_Delete [col_row]_R2.sm (41 КиБ) скачан 67 раз(а).
overlord 03.06.2021 21:45:00, Alvaro Diaz Falconi 02.06.2021 17:53:00
#8 Опубликовано: 02.06.2021 18:12:03
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi Amarasekera. Please try this other version, which works for single column values or column ranges.
New_Matrix_Delete [col_row]_R2.sm (38 КиБ) скачан 71 раз(а).
overlord 03.06.2021 21:45:00, NDTM Amarasekera 02.06.2021 23:47:00
#9 Опубликовано: 02.06.2021 18:35:44
Utilities Matrix Minor [col_row] ADVANCED OTHERWISE Copy.sm (97 КиБ) скачан 70 раз(а).
NDTM Amarasekera 02.06.2021 23:48:00
