"Plug-in(s) installation failed" error - Сообщения
#1 Опубликовано: 21.09.2018 14:00:45
#2 Опубликовано: 21.09.2018 14:19:29
Hmm. I can't reproduce this issue.
#3 Опубликовано: 21.09.2018 14:44:15
Again tried to install MapleWrapper, but same problem.
Then I get another problem with WriterRegion. Some link????
The only way for me was to do a clean re-installation without trying to install MapleWrapper, and then WriterRegion can be installed. Any attempt to install MapleWrapper will trigger the same problem with WriterRegion. I don't know why?
#4 Опубликовано: 21.09.2018 14:58:52
Try to remove SMath Studio and extensions manually.
#5 Опубликовано: 21.09.2018 15:04:42
Yes I did it several times without success.
Also pl see my edited post above.
#6 Опубликовано: 21.09.2018 15:21:52
I deleted the new build. Try the previous version.
#7 Опубликовано: 21.09.2018 15:26:36
Yes, it now works fine. Thank you.
#8 Опубликовано: 21.09.2018 15:35:19
TextRegionUtilities might be involved in the issue?
#9 Опубликовано: 21.09.2018 15:42:19
Very strange behavior. I made only small changes today and for me all works fine.
#10 Опубликовано: 21.09.2018 16:52:56
Davide Carpi 21.09.2018 17:05:00
#11 Опубликовано: 22.09.2018 12:23:47
Attached file last opened and saved on 11/09/2018, but now
fails due to MathcadFileAccess plugin failing to install.
P_day_Avg & P_day_Mov. Avg.sm (37 КиБ) скачан 49 раз(а).
#12 Опубликовано: 22.09.2018 12:47:07
#13 Опубликовано: 22.09.2018 13:38:44
I think only Andrey can help here. Something wrong with your environment.
NDTM Amarasekera 23.09.2018 05:05:00
#14 Опубликовано: 22.09.2018 14:31:26
I've tried several combinations but I'm unable to reproduce as for now.
If you rename the "SMath" folder contained in %APPDATA% into something else and then you reinstall the extensions the issue still appears?
P.S. moved the messages here since it seems not related with a specific plugin.
Вячеслав Мезенцев 22.09.2018 14:47:00
#15 Опубликовано: 22.09.2018 15:24:49
Thank you Davide. Your suggestion worked fine, with all necessary plug-ins installed,
and all the programs running smoothly.
Also thank you uni, for all the encouragements.
#16 Опубликовано: 22.09.2018 16:47:36
Hello.
I'm aware about this issue. It happens only in the following case:
1) New version of SS released;
2) New version of the plug-in for latest SMath Studio released;
2) New version of the plug-in for old version of SMath Studio released.
In this case there are couple of issues happens on server side which breaks behavior of the Extensions Manager.
It is absolutely clear how to fix this, but it requires a time. I plan to address it as soon as possible.
As for today new stable version of SMath Studio released and if you'll find any issues with plug-ins installation just rebuild and publish plug-ins for this latest version. Issue will gone.
#17 Опубликовано: 23.09.2018 04:37:55
WroteI think only Andrey can help here. Something wrong with your environment.
I believe the reason for failure to install plug-in(s) was an Antivirus Program (NOT Kaspersky).
After successfully installing latest SS "0.99.6839.38235" with necessay plug-in(s), problems cropped up again with CephesMathematicalLibrary, MapleWrapper, ODESolvers and a few.
I had to struggle to configure the Antivirus package to prevent blocking installing above plug-in(s).
Now SS is working without any apparent hassle.
#18 Опубликовано: 27.09.2018 12:11:57
I have the same problem with the Smath update, but with Excel plug-in.
Smath version: 0.99.6839
EXCEL I/O with recalculation and PNG export version: 1.99.6354.6352
#19 Опубликовано: 27.09.2018 14:17:42
WroteI have the same problema with the Smath update, but with Excel plug-in.
Yes, I too get this error. But, all efforts to configure the Antivirus package failed.
I do not know whether changing the Antivirus program will solve this.
Somebody may be able to help you.
Sorry. I am using a paid version of the Antivirus.
#20 Опубликовано: 27.09.2018 17:21:54
This is not one of the cases above. That plugin isn't updated to the latest API, hence it fails to install (in the extension page you can see that the latest version was released at 2017-05-25)
NDTM Amarasekera 27.09.2018 22:00:00
Новые сообщения
Нет новых сообщений
