1 страниц (5 вхождений)
Table Region PlugIn - Showing calculated values in caption or footnote - Сообщения
#1 Опубликовано: 29.01.2020 07:42:47
The Table region PlugIn is very useful (thanks Davide!) and nice, but I wonder if there is any way to show a calculated value in between other text in the caption (or footnote) field.
I see that there are special keys (%T, %S, %R etc.) to show some particular numbers in the caption, it would be interesting and useful to have, let's say, %V(varname) to show the value of a variable of the sheet.
Does anyone know a workaround or maybe this could be a future additional feature?
Thanks
Marco
Thanks
Marco
#2 Опубликовано: 29.01.2020 09:19:06
Marco: not sure what you are looking for ?
Table Region [Project].sm (9 КиБ) скачан 160 раз(а).
Table Region Carlos.sm (17 КиБ) скачан 122 раз(а).
Table Region.sm (49 КиБ) скачан 119 раз(а).
Levenberg_Marquardt_Code_CBG Model.sm (70 КиБ) скачан 97 раз(а).
#3 Опубликовано: 29.01.2020 11:05:32
Jean, thanks for your help, your examples always have interesting hints.
However, what I would like to do is something like this below:
I would like to show a variable value in place of "xxxx" in the caption of the above table.
I have not found any way to do that and probably it is not possible, for the actual version of this plug-in.
Any suggestion welcome.
Thanks
Marco
Thanks
Marco
#4 Опубликовано: 29.01.2020 12:22:10
WroteI would like to show a variable value in place of "xxxx" in the caption of the above table.
... as live variable probably not possible.
If you say and tabulate the calculated values are normalized
at some speed xxx RPM then write it as such
All data normalized @ 3600 RPM
#5 Опубликовано: 29.01.2020 14:00:52
You could just place a formatted label region over the caption . This is a bit weird but it works. Use the context menu to switch off input and border.
label.sm (4 КиБ) скачан 82 раз(а).
In newer SMath versions, you can also use a standard text region with an embedded formula, where you can suppress input display and even specify a unit.
Новые сообщения
Нет новых сообщений
