1 страниц (5 вхождений)
Eigenvalues and eigenvectors - Сообщения
#1 Опубликовано: 03.12.2020 17:34:07
Is there a built in function for extracting eigenvalues and eigenvectors from matrices?
Thanks
Thanks
#2 Опубликовано: 03.12.2020 17:58:31
Hi. Try this plugin
https://en.smath.com/forum/yaf_postst1918_DotNumerics.aspx
There you have dn_LinAlgEigenvalues and other for Eigenvectors
#3 Опубликовано: 03.12.2020 18:57:42
This is my attempt for do eigenvectors without plugins. Sometimes give better values than dot numerics, and other times fails, because I haven't a simple code for do the pseudo inverse for this code, and use SMath's inverse() which have some bugs.
MEigen with rref.sm (103 КиБ) скачан 76 раз(а).
MEigen with rref.pdf (296 КиБ) скачан 70 раз(а).
sergio 04.12.2020 06:21:00
#4 Опубликовано: 03.12.2020 22:50:07
WroteIs there a built in function for extracting eigenvalues and eigenvectors from matrices?
Visit this Companion ...
Maths eigenAll Companion.sm (66 КиБ) скачан 121 раз(а).
#5 Опубликовано: 04.12.2020 08:52:49
Thanks everybody.
Новые сообщения
Нет новых сообщений
