function maximize/minimize in Smath Studio
function maximize/minimize in Smath Studio - Help! - Сообщения
#1 Опубликовано: 28.04.2021 16:47:54
Denis
Denis
0 сообщений из 14 понравились пользователям.
Hi, guys
I need help for my graduation work, i need to use maximize function in Smath Studio, but i have no idea how to do it .
Is there a plugin for maximize / minimize functions in Smath Studio?
#2 Опубликовано: 28.04.2021 22:58:15
555 сообщений из 1333 понравились пользователям.
Hi, guys
You can write your own functions.
maximize and minimize are peak points of slope.
Take derivative of equation, solve it.
Check the examples below.
maximize_minimize.sm (16 КиБ) скачан 134 раз(а).
maximize_minimize with different solvers.sm (28 КиБ) скачан 118 раз(а).
Alvaro Diaz Falconi 29.04.2021 00:29:00
#3 Опубликовано: 29.04.2021 09:00:50
Denis
Denis
I have a program in MathCad,the problem is that the marshmallow recipe is being optimized here,
I need a maximization function to find the maximum value of each ingredient.
sbalansir. + organoleptika zefira - f-cii Ketle.xls (21 КиБ) скачан 69 раз(а).
the exel file contains the values ​​of each marshmallow component that are used in the task.
sbalansir. + organoleptika zefira - f-cii Ketle.xmcd (250 КиБ) скачан 69 раз(а).
The whole problem is that the function K(x) is six-dimensional and there is no idea how to find its derivatives.
I need to do the same in Smath Studio, but there are no Given / Maximize / Minimize functions in Smath,
I don't know how to implement this.
Here is everything that I could implement in Smath from the Mathcad file.
diplomnayaRabota.sm (33 КиБ) скачан 76 раз(а).
p.s If something is not clear, ask, I will try to answer.
Sorry for my bad eng
#4 Опубликовано: 29.04.2021 09:22:32
Alvaro Diaz Falconi
Alvaro Diaz Falconi
997 сообщений из 1676 понравились пользователям.
Hi, can you upload a pdf instead the mathcad xmcd file, please?
#5 Опубликовано: 29.04.2021 09:56:41
Denis
Denis
everything is written in Russian, if you have any questions, I will explain.
Mathcad - sbalansir. + organoleptika zefira - f-cii Ketle.pdf (245 КиБ) скачан 85 раз(а).
#6 Опубликовано: 29.04.2021 10:18:43
Denis
Denis
Hi, guys
Unfortunately, this does not work with my function, because it is more complex than yours.
#7 Опубликовано: 29.04.2021 11:44:59
gallyon1
gallyon1
Why are denominators 0? B2j≠B1j. Am i wrong?
#8 Опубликовано: 29.04.2021 12:16:06
Here is the first solution for your graphics. Rest are in the example.
This is an ugly and fast solution compiled in a haste.
I am pretty sure someone in the forum will come with a more classy method.
diplomnayaRabota_rev.sm (40 КиБ) скачан 76 раз(а).
Denis 29.04.2021 13:03:00
#9 Опубликовано: 29.04.2021 12:38:37
Denis
Denis
diplomnayaRabota_rev.sm (40 КиБ) скачан 72 раз(а).
Thanks for your feedback , but I need to calculate maximize from the function K(x),
not from y(j, x).
Check this pdf Mathcad file:
Mathcad - sbalansir. + organoleptika zefira - f-cii Ketle.pdf (245 КиБ) скачан 78 раз(а).
After the function K (x), the vector x is given as the initial approximation
and after that the Given and Miximize functions are used for the K(x) function.
I need to get vector X in Smath.
p.s sorry for my bad eng
#10 Опубликовано: 30.04.2021 06:31:24
Denis
Denis
Graphs are doctored and more, but can't sanity more
Cheers ...Jean
diplomnayaRabota.sm (45 КиБ) скачан 78 раз(а).
Thanks for your corrections , but the main question was how to get this vector X without the Given and Maximize functions,
because it's obtained from these functions: "X: = Maximize (K, x) ?
#11 Опубликовано: 30.04.2021 07:24:17
That is a total different solver. Smath don't have it integrated.
Maple software has it as Maximize() and Minimize() but plugin doesn't parse it under linux.
At least I couldn't do it with maple plugin.
Maxima can solve that kind of equations with maximize_lp() and minimize_lp().
You have to load(simplex) before using this two functions.
Maybe maxima plugin could work but I can't try it, need a windows user to try it.
I use maxima under terminal, maxima plugin doesn't work with linux.
Regards.
#12 Опубликовано: 30.04.2021 09:03:36
Denis
Denis
The bloc solver Given ... Find, Minerr, Maximize, Minimize
is Mathsoft proprietary specific to Mathcad. No such equivalent Smath.
Given/Minerr for fitting model function to data set is done otherwise
in Smath via Conjugate Gradient ... same or even better.
If there is another way of doing in Smath, expect Designers to help.
Sorry Collab, can't help directly on that ... Jean.
I tried to do this for a simple function through the "roots" function, and in the end I found the maximum,
finding the maximum for a simple function.sm (12 КиБ) скачан 106 раз(а).
but there are no ideas how to do this for K (X), since it depends on 6 arguments of the vector x.
Is it possible to somehow implement the same algorithm in my task?
#13 Опубликовано: 01.05.2021 07:42:10
Denis
Denis
Is it possible to somehow implement the same algorithm in my task ?
The Ancestor of the savant solve is the TKsolve.
The designers of TKsolve are the Founders of Mathsoft/Mathcad.
No Mathcad gurus succeeded to crack the bloc, probably crypted deep.
It's a pity that this method is not solved.
#14 Опубликовано: 01.05.2021 16:57:32
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi. There are no minimizers in SMath, with the probable exception of a library in Maxima that can be read and executed, as Overlod point.
However, a kind of minimizer can be implemented as shown in the attached, and incidentally, obtain a solution (just a little bit) better than Mathcad's.
diplomnayaRabota_nleqsol.sm (83 КиБ) скачан 137 раз(а).
Denis 01.05.2021 20:09:00
#15 Опубликовано: 03.05.2021 08:00:05
Denis
Denis
Thank you so much for your work. I appreciate it.
#16 Опубликовано: 04.05.2021 08:14:35
Denis
Denis
Hi, I didn't really understand how you made such a function for the previous maximize problem,
I wanted to ask you to help me solve a simpler problem on this topic.
Milk shake optimization.sm (17 КиБ) скачан 92 раз(а).
pdf Mathcad file:
Mathcad - mag.2020 Aleksandr Baranov Optimizacija molochnogo koktejjlja.pdf (99 КиБ) скачан 107 раз(а).
In this program, I need to repeat everything in the same way as in the screenshots of MathCad, i attached them to Smath.
I would be very grateful if you could help me.
If you have any questions, ask, I will answer them.
#17 Опубликовано: 04.05.2021 11:41:17
Denis
Denis
In this program, I need to repeat everything in the same way as in the screenshots of MathCad, I attached them to Smath
Horrible screen shot, nothing to see for understanding.
Seemingly, you have a system to solve ... something like Butler.
Solve Given_Find [CO2_6179 Butler].sm (162 КиБ) скачан 77 раз(а).
I'll try to make a pdf Mathcad file.
Some formulas simply dont fit into the full sheet and go beyond the boundaries.
#18 Опубликовано: 04.05.2021 13:33:46
Denis
Denis
Some formulas simply don't fit into the full sheet and go beyond the boundaries.
Your Mathcad document is surely badly dressed.
like it turned out to make pdf
#19 Опубликовано: 04.05.2021 17:08:24
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi. Point is: how to solve that in SMath? Because SMath haven't maximizer, and what you have near to that is al_nleqsolve, you can read that in this way: How to use a traditional solver for seek a maximum with constraints?
So, you have a function K(x) with x element of R^6, a guess xo and the guess value for the maximum K(xo). First, write Check(x), for restrict x for the constraints. Next, because numerical solvers for roots needs the evaluation of the change in the target value, assume that you are looking for the zero of f(x) = K(x) - (1+p)*Ko, where p is some percent increment over Ko. Why? Because you guess that xo it's a good solution, so, Ko = K(xo) "must" to be a good guess for the maximum. The Maximize ad hoc function it's just the implementation for that: here the trick is use K(Check(x)) instead K(x). You can try to change the p-value for get the best answer that you can.
The Mathcad's screenshots are perfect. Here you have a little difference: the restrictions involving another function Kc(x), but it's very similar, and need to write CheckX for x and CheckKc for Kc(x). The trick for CheckKc(x): No one, but three:
First, return some information to the solver about how the things are going. Instead of return 0 or 1, return 0 for Kc is in the good interval, and +/- normi(x) if not.
Second, include CheckKc(CheckX(x)) as second row in the target function for try to get zeros on both components.
Third, include CheckKc in the exit condition for the main loop.
Milk shake optimization nleqsol.sm (1 МиБ) скачан 107 раз(а).
Hope that's helps.
Denis 04.05.2021 18:05:00
#20 Опубликовано: 04.05.2021 19:21:08
1418 сообщений из 2874 понравились пользователям.
You might try even these
GoldenSectionSearch.sm (21 КиБ) скачан 322 раз(а).
GradientDescent.sm (16 КиБ) скачан 273 раз(а).
NCGM.sm (19 КиБ) скачан 259 раз(а).
LevenbergMarquardt.sm (45 КиБ) скачан 291 раз(а).
NewtonMethod.sm (18 КиБ) скачан 320 раз(а).
NelderMead.sm (33 КиБ) скачан 265 раз(а).
GaussNewton.sm (20 КиБ) скачан 292 раз(а).
