function maximize/minimize in Smath Studio - Help! - Сообщения
#21 Опубликовано: 04.05.2021 20:33:27
hello. I have the same problem with the transfer from mathkad to smath and the maximize function
. Could you help me? I would really appreciate it
. Sorry English is not perfect either here or in the pdf fileMathcad - mag. 2020 Vershinina Ehvelina Optimizacija slivochnogo krema1.pdf (113 КиБ) скачан 81 раз(а).
#22 Опубликовано: 04.05.2021 20:53:18
Wrotehello. I have the same problem with the transfer from mathkad to smath and the maximize function ...
Hi. If you upload the SMath file maybe someone can help you.
#23 Опубликовано: 05.05.2021 04:35:10
yeah totally forgot about it
sbalancirovannost_39__organoleptika_zefira_-_f-ii_Ketle_new.sm (19 КиБ) скачан 78 раз(а).
#24 Опубликовано: 05.05.2021 07:27:06
Wroteyeah totally forgot about it
Hi. You have an issue here, and I don't know if it's because SMath can't calculate very well the exponential function or why, but the value for Ko(x) aren't the same in Mathcad and SMath, and thus the values for the target function K(x).
In the attached, the procedure for the "ad hoc" minimizer.
sbalancirovannost_39__organoleptika_zefira_-_f-ii_Ketle_new.sm (53 КиБ) скачан 83 раз(а).
gallyon1 07.05.2021 11:49:00
#25 Опубликовано: 05.05.2021 08:04:26
Oh I see thank you
But final answer doesnt look like in MathCad
sbalancirovannost_39__organoleptika_zefira_-_f-ii_Ketle_new (3).sm (53 КиБ) скачан 75 раз(а).
#26 Опубликовано: 05.05.2021 10:30:31
WroteOh I see thank you
Hi. You must to choose the adequate parameter "percent" p for see if you can raise up the maximum. For instance this other seems to hold all the restrictions with a maximum only just 8 orders of magnitude bigger than Mathcad answer. Try to put the SMath xo value in Mathcad as new guess for the solve block and see if you get the same maximum for K(x) in Mathcad.
sbalancirovannost_39__organoleptika_zefira_-_f-ii_Ketle_new.sm (90 КиБ) скачан 87 раз(а).
#27 Опубликовано: 07.05.2021 10:35:31
If i use this x0 in MathCad I get the same XФайл не найден.. x=X. I tried a lot of p values but I didnt get close result. Results are always too big.Файл не найден.
#28 Опубликовано: 07.05.2021 13:19:13
WroteIf i use this x0 in MathCad I get the same XФайл не найден.. x=X. I tried a lot of p values but I didnt get close result. Results are always too big.Файл не найден.
Hi gallyon1. You are looking for a maximum. So, for your problem, bigger is better. SMath returns a bigger result, but that's not all: the results verify all the problem constraints, which make it valid answer for the problem.
Maybe I don't explain well: try to check what happen with mathcad if you use the SMath answer as the guess, this is substitute the x value in Mathcad for the xo value from SMath here:
But actually that's for compare. SMath solution checks all the constraints, then it's a candidate for the problem solution. You "didn't get close result", but I don't see a problem there, where I see a problem is if you want a close result, this is a result near to 8.8*10^8 you need to review your physical system and check if there are some additional constrictions for some variable or function which make your result "close" to that value. If not, SMath solution it's just a good solution, and Mathcad's isn't.
Новые сообщения
Нет новых сообщений
