Beta: SMath Studio 0.99.6965 (26 January 2019) - Сообщения
Changes introduced in current build 0.99.6965
Исправления
- Support for evaluation plug-ins improved.
Разное
- Math toolbar improved to support high dpi environments;
- Refactoring.
Download
SMathStudioDesktop.0_99_6965.Mono.tar.gz (1 МиБ) скачан 704 раз(а).
SMathStudioDesktop.0_99_6965.Setup.msi (2 МиБ) скачан 2050 раз(а).
Please note:
- There are some known bugs with Worksheet scrolling - will be addressed soon;
- There are some UI issues on environment with high DPI (some Custom plug-ins may not be scaled correctly).
Please use the following to disable high dpi support if required:
To all developers:
As you may notice starting from build 0.99.6955 SMath Studio supports high DPI and in order to scale Regions correctly we have to introduce new requirement:
- Plug-in must use SMath.Drawing.Graphics instead of System.Drawing.Graphics everywhere.
or
- All Fonts created by the plug-in must have GraphicsUnit.Pixel specified as a unit and size must be multiplied by 96f / 72f in order to convert Points to Pixels.
All existing plug-ins should be updated according to this requirement as everything looks ok while system is configured to have use 96 DPI, but in all other cases scaling of Fonts in plug-ins is incorrect.
All modern platforms like iOS, Android, UWP have Pixel specified as a unit by default, so this issue appears on Windows machines only (we have it on Linux as well because of Mono).
Please let me know in case of any related questions. If you are not able to perform changes by yourself - just let me know and I will update plug-ins by myself.
Best regards, Andrey Ivashov.
В версии SMathStudio 0.99.6954 съезжают размеры вставленных картинок.
Т.е. они были вставлены и уменьшены до нужного размера, файл был сохранен.
Но при открытии они снова становятся большими, т.е. программа не запоминает манипуляции с их уменьшениями.
На старых версиях такого не было.
В версии SMathStudio 0.99.6965 можете открыть прикрепленный файл ... как там будет? Будет ли съезжать после редактирования и сохранения?
Спасибо!
Raschet glukhikh naruzhnykh nenesushchikh sten.sm (652 КиБ) скачан 69 раз(а).
WroteThis was a bug introduced in SS 0.99.6954, fixed in the immediately following version (0.99.6955). The choosen size was still saved but that version wasn't able to restore it properly. Your file in current version looks like in the attached picture, that I believe should be correct.
Спасибо!
Тогда обновлюсь
Have you planned to update the cloud version to this new one?
I find out it very convenient.
Time of desktop apps is passing by.
Good luck in your job.
WroteGreat job!
Yes, usually I'm updating Cloud version with stable versions only (with some exceptions).
Новые сообщения
Нет новых сообщений
