SMath Studio 0.99.6638 (05 March 2018)
SMath Studio 0.99.6638 (05 March 2018) - Сообщения
#1 Опубликовано: 05.03.2018 14:40:47
2270 сообщений из 3734 понравились пользователям.
Группа: Super Administrator
Changes introduced in current build 0.99.6638
Download
SMathStudioDesktop.0_99_6638.Mono.tar.gz (1 МиБ) скачан 741 раз(а).
SMathStudioDesktop.0_99_6638.Setup.msi (2 МиБ) скачан 2127 раз(а).
9 пользователям понравился этот пост
Martin_B 05.03.2018 14:57:00, sergio 05.03.2018 14:59:00, Serg 05.03.2018 15:22:00, Вячеслав Мезенцев 05.03.2018 15:39:00, frapuano 05.03.2018 16:34:00, Martin Kraska 05.03.2018 19:30:00, NDTM Amarasekera 05.03.2018 22:46:00, Davide Carpi 06.03.2018 09:37:00, IVR 06.03.2018 13:29:00
#2 Опубликовано: 05.03.2018 16:01:34
For those interested to test useful functionalities 6638
Utilities Matrix_Vector [MCD 4 styles].sm (34 КиБ) скачан 89 раз(а).
#3 Опубликовано: 05.03.2018 16:17:36
Observe ... Q(i,j) is already code "trace"
#4 Опубликовано: 05.03.2018 18:11:59
CBG
CBG
77 сообщений из 312 понравились пользователям.
Every time Smath Studio is updated, something goes wrong. Again failed
to start the plugin Table Region, Smath Studio does not recognize it.
Carlos
#5 Опубликовано: 05.03.2018 18:25:50
Carlos,
Yeah, its a life...
Fixed (please update a plug-in). Thank you!
#6 Опубликовано: 05.03.2018 21:18:38
CBG
CBG
It already works!
Thank you very much.
Carlos
#7 Опубликовано: 05.03.2018 22:23:16
That's why I'm 6179 for productive projects.
#8 Опубликовано: 05.03.2018 22:49:16
#9 Опубликовано: 05.03.2018 22:51:23
#10 Опубликовано: 06.03.2018 03:44:16
In this case you have to live with slow performance, tens of critical known (and already fixed) bugs. You can't use new features and make your future switch to newer version harder. There is no even any guarantee that your worksheets can be supported by latest SMath Studio versions (yeah, in SMath history we had couple of such situations when a part of calculation can not be handled anymore, unfortunately).
So, I can't say that it is good approach.
#11 Опубликовано: 06.03.2018 03:46:47
Are you kidding? And what about 2.35, -9.465 and etc?
#12 Опубликовано: 06.03.2018 13:03:49
Page11 Floor.sm (12 КиБ) скачан 88 раз(а).
#13 Опубликовано: 14.03.2018 18:46:18
Alexander O. Melnik
Alexander O. Melnik
127 сообщений из 494 понравились пользователям.
A bug in functionality of vectorize() was introduced between 0.99.6617 and 0.99.6638. Will this be addressed?
#14 Опубликовано: 15.03.2018 01:09:35
That it was introduced between 6617 & 6638, that is surprising ?
Even if it did work, to me, it is not correct because it will cause
something wrong sooner or later, because to reflexive in the
calculation kernel ... Murphy's law. I have experimented disastrous
situations [crash ... push the button to stop].
Occasionally, to isolate, you have to spool to file.
Cheers Alex ... Jean
#15 Опубликовано: 15.03.2018 14:12:50
Jean are right, this didn't work initially, but started working at some point because of another bug Yes, I'm not kidding.
I've investigated this example and was able to make it work together with all other examples I have about vectorize(..) function. All tests executed OK.
So, I decided to include this improvement into new release: https://en.smath.info/forum/yaf_postst12594_RC-0-99-6648--15-March-2018.aspx
Please test examples you have with vectorize(..) function.
sergio 15.03.2018 15:12:00
