Graphs Scaling
Graphs Scaling - Сообщения
#1 Опубликовано: 10.03.2015 09:45:37
sperez
sperez
Is it possible to control the scale of the graph axes, using code within the document or an option somewhere.
I'm trying to make the scale conform to a specified domain and range so the graph generated by my functions doesn't have to be manually adjusted every time a variable is changed.
Best Regards,
Santiago
#2 Опубликовано: 13.03.2015 15:34:48
Hello Santiago,
For precise scaling/limits you have to use a plugin, such as Maxima plugin (examples) or X-Y Plot Region
A further help is inside the extension mangager (Tools > Plugins...) > Interactive handbooks; here there is the SMath Studio Handbook, that contains a Graphics section. (You have to download it, set it to use as default, then will be available from the Help > Reference book... menu)
