Range Function Power Bug
Range Function Power Bug - Сообщения
#1 Опубликовано: 21.01.2021 15:08:22
Tow Wai Lim
Tow Wai Lim
0 сообщений из 42 понравились пользователям.
How can I equate power of range to the following? How can we solve this error, anything power should be 1.
When a range is square, the return answer is total of square value.
Page5.sm (9 КиБ) скачан 40 раз(а).
#2 Опубликовано: 21.01.2021 16:15:00
As you evaluate over a vector, use the vectorize operator.
#3 Опубликовано: 21.01.2021 16:22:18
Tow Wai Lim
Tow Wai Lim
I tried to vectorize the following. What have I done wrong?
Page6.sm (5 КиБ) скачан 49 раз(а).
#4 Опубликовано: 21.01.2021 16:40:37
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi. There the problem is 0^0, it is undefined, at least in SMath environment, and probably it's the best choice: return an error if appear. That for the vectorization. About w^0, without vectorization, seems that SMath try to do a scalar product, like in w^2. Remember that a^0 = 1 for a <> 0 it's by definition, not by any theorem.
#5 Опубликовано: 21.01.2021 16:43:05
Ruben Sidranski
Ruben Sidranski
17 сообщений из 463 понравились пользователям.
Delete thehat are you trying to do? Everything is defined, yet, you have a range for the answer. Are you looking to plot?
#6 Опубликовано: 21.01.2021 16:55:12
Tow Wai Lim
Tow Wai Lim
I am trying to plot and integrate, but no luck
Page4.sm (20 КиБ) скачан 49 раз(а).
#7 Опубликовано: 21.01.2021 16:59:52
Tow Wai Lim
Tow Wai Lim
I just need to put a very small values instead of zero.
#8 Опубликовано: 21.01.2021 17:04:49
No luck because NO function, always plot the function you want to integrate.
Pure suggestion attached ... Jean
Page4.sm (35 КиБ) скачан 43 раз(а).
#9 Опубликовано: 21.01.2021 17:25:02
Ruben Sidranski
Ruben Sidranski
For inspiration. Heat Capacity Function1.sm (20 КиБ) скачан 86 раз(а).
Let me know if you cannot open it. Jean had an issue when I posted it yesterday
#10 Опубликовано: 22.01.2021 12:02:43
Oh ! Elsid ... wrong format.
Our Win systems are not companions !
Take care ... Jean
