plot function
plot function - The derivative of a function does not appear - Сообщения
#1 Опубликовано: 10.12.2019 10:32:25
Ale16595
Ale16595
0 сообщений из 35 понравились пользователям.
Hello everybody.
I can't understand why the phi function does not compare in the graph.
This function is the derivative of the phi function that instead appears in the graph.
Someone could help me please?
Thanks in advance
this is the file… Derivate.sm (22 КиБ) скачан 59 раз(а).
#2 Опубликовано: 10.12.2019 12:31:00
1. your φ(t) plots correct
2. The Smath derivative operator works on derivative rules.
3. The φ(t) is too much a monkey business for derivative rules.
4. Rescue via transit infinitesimal analysis.
5. Your constrain in plot argument is obsolete since if/otherwise
was introduced by Davide from f(x) menu "cases".
Derivate (1 doctored).sm (24 КиБ) скачан 57 раз(а).
#3 Опубликовано: 10.12.2019 14:36:26
Ale16595
Ale16595
Thanks for the reply, I solved this problem.
Now, however, an error appears that does not make me draw a graph.
the error says: "The result is higher than the maximum positive value allowed"
what does it mean?
curvatura.sm (48 КиБ) скачан 59 раз(а).
#4 Опубликовано: 10.12.2019 17:30:44
what does it mean?
... doctored version works top2bottom
1. Remember λ(x) as used
2. More problem(s) ... return the doctored version.
3. Delete all the black
curvatura (1 doctored).sm (53 КиБ) скачан 61 раз(а).
#5 Опубликовано: 10.12.2019 18:39:51
Alvaro Diaz Falconi
Alvaro Diaz Falconi
what does it mean?
Hi. Means that' you have divide by zero or something other invalid operation. You must to avoid that for plots with restrictions in the ranges, or with try ... on error in a routine for range plots. Attached have this second option.
curvatura - moto v2.sm (43 КиБ) скачан 63 раз(а).
curvatura - moto v2.pdf (371 КиБ) скачан 53 раз(а).
sergio 11.12.2019 06:03:00
#6 Опубликовано: 11.12.2019 01:38:57
Alvaro Diaz Falconi
Alvaro Diaz Falconi
This technique enable the view of symbolics.
curvatura - moto v3.pdf (460 КиБ) скачан 74 раз(а).
curvatura - moto v3.sm (1 МиБ) скачан 65 раз(а).
