1 страниц (8 вхождений)
3D-Scatter Plot - How can I plot it - Сообщения
#1 Опубликовано: 05.05.2023 06:29:56
How can I plot 3-D diagram? So for example.
See please the SMath attach!
GTU-Ro-T.sm (383 КиБ) скачан 51 раз(а).
#2 Опубликовано: 05.05.2023 08:32:19
WroteHow can I plot 3-D diagram? So for example.
1. Arrays dimension do not match.
2. Once doctored, maybe Maxima.
#3 Опубликовано: 05.05.2023 09:25:47
#4 Опубликовано: 05.05.2023 12:11:50
If the Maxima Plugin is an option for you, then just create a n x 3 data matrix and plot it using Draw3D. You find more plot examples in my Handbuch (section 8.1).
![2023-05-05 17_05_28-SMath Solver - [GTU-Ro-T.sm_].png](/ru-RU/file/nWAraA/2023-05-05-17_05_28-SMath-Solver---_GTU-Ro-T_sm___png)
GTU-Ro-T_Kr.sm (395 КиБ) скачан 53 раз(а).
#5 Опубликовано: 05.05.2023 15:06:56
thank you for your hard work... i am learning Smath because im fed up with ptc bullcrap.
ohh how i wish i had mCad 15 on this computer, but dont have my original disk...plus this is an opportunity to become a better programmer, learning
from all of the work on plug-ins etc...
hopefully we can some day graph a 3d scatter plot which will do what i did years ago with Mcad.
enjoy the clip..i may have smoked too much at that the time i made it.
In response to this Thread...I have a question.. I modified points-joined=false and it works, but how can I get Points instead of little crosses?
Funny Orbits 3.zip (3 МиБ) скачан 49 раз(а).
#6 Опубликовано: 05.05.2023 16:29:48
Also you can use a 3x2 matrix for rotate and project 3-D data into 2-D for plot it.
GTU-Ro-T.sm (397 КиБ) скачан 52 раз(а).
#7 Опубликовано: 05.05.2023 17:16:54
... differently by doing what's wanted.
3D Plot.sm (61 КиБ) скачан 57 раз(а).
3D Axes System XYZ User Explorer.sm (52 КиБ) скачан 56 раз(а).
3D Axes System Parametric Explorer.sm (21 КиБ) скачан 57 раз(а).
3D Solid cut by Surface.sm (72 КиБ) скачан 56 раз(а).
#8 Опубликовано: 05.05.2023 21:04:08
...project 2D on 3D
Analemma [Project_Anim].sm (33 КиБ) скачан 49 раз(а).
Analemma PROJECTION.sm (81 КиБ) скачан 50 раз(а).
Новые сообщения
Нет новых сообщений
