Integration problem with user defined function with units in Latest SS 0.99.6877
Integration problem with user defined function with units in Latest SS 0.99.6877 - Сообщения
#1 Опубликовано: 30.10.2018 23:16:55
NDTM Amarasekera
NDTM Amarasekera
Thank you Andrey for the latest SS 0.99.6877.
However, I observe a problem in integrating a user defined function with units.
The attached SS document (and all similar docs) worked fine in all previous SS versions without any issue.
Malwala Reservoir Flood Capacity Estimation-Simple.sm (249 КиБ) скачан 53 раз(а).
sergio 31.10.2018 05:16:00
#2 Опубликовано: 31.10.2018 03:23:38
Группа: Super Administrator
Thank you!
For some reason I had no automated test with such example (integral with units) and that is why I didn't catch this error before the latest beta release.
Will add example to tests and make a fix asap.
Thanks for the report!
Arie 31.10.2018 10:30:00, NDTM Amarasekera 05.11.2018 12:56:00
#3 Опубликовано: 06.11.2018 22:45:46
NDTM Amarasekera
NDTM Amarasekera
Thank you Andrey for the fix.
Andrey Ivashov 07.11.2018 02:31:00
