1 страниц (7 вхождений)
Solve() throws "No real roots" - Polytropic Calculation - Сообщения
#1 Опубликовано: 08.12.2017 14:59:19
I am using the latest version of Smath Studio & have seen many other threads on this forum regarding similar issue. I don't want to use xMaxima addin because of portability issue with Maxima distribution. If some however can provide a link to portable Maxima package it will be greatly appreciated
Coming back to the issue please see the attach file as my solve command for polytropic compressor calculations fails. Equations does include units ...from a preview (tooltip) of eq2 I see no problem but solve() throws error
Page1.sm (7 КиБ) скачан 120 раз(а).
#2 Опубликовано: 08.12.2017 16:11:08
You really don't need to use the solve function here as you already have an expression for power. Consider pre-defining eq.2 and simply evaluating it as needed as shown in attached. Page1.sm (9 КиБ) скачан 138 раз(а).
#3 Опубликовано: 08.12.2017 23:05:48
Wrotesolve command for polytropic compressor calculations fails.
construct the right way, like this.
Ioncube.sm (11 КиБ) скачан 205 раз(а).
#4 Опубликовано: 11.12.2017 13:29:36
Thanks for the great help guys. Much appreciated. Can I ask one more thing (because I have prior experience to Geogebra)
In my file lets assume that I want to see the effect of increasing T2 upon CompressorPower as well as Efficiency ....a graph will suffice! Back in Geogebra I would have created a list of T2 (from say 160 to 300 with 10 as increment) & would get the calculated parameters also in a list ...these lists will then be converted to coordinates (x,y via list to matrix manipulation) & will be ready for plot
#5 Опубликовано: 11.12.2017 16:16:55
This is one way to do it. Page1 (2).sm (8 КиБ) скачан 144 раз(а).
#6 Опубликовано: 11.12.2017 17:52:04
WroteIn my file lets assume that I want to see the effect of increasing T2
Just like this => solve for n as many as you wish
Administrate the remaining of the project at will wrt those n
Cheers mon ami.
Ioncube.sm (17 КиБ) скачан 104 раз(а).
Новые сообщения
Нет новых сообщений
