Maxima Plugin
Maxima Plugin - Сообщения
#261 Опубликовано: 13.03.2019 01:34:13
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi. Can the Maxima plugin beheavior could be changed to agree with SMath (and Mathcad) diff operator, when the variable is defined?:
MaximaDiff.sm (6 КиБ) скачан 98 раз(а).
Thanks in advance for your answer.
#262 Опубликовано: 13.03.2019 06:04:29
This would require access to the unevaluated (non-preprocessed) verbatim expression from within the plugin. I don't know if that is currently possible. Same problem applies for definite integrals for numeric evaluation. I could take over numeric quadrature as well if I had access to the unevaluated expression.
Perhaps our other developers have a quick anwer?
#263 Опубликовано: 13.03.2019 07:01:44
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi Martin. Clean() seems to have this kind of access.
#264 Опубликовано: 13.03.2019 09:54:01
Clear() is defined in the Special functions plugin, which is closed source and probably isn't restricted to the third party plugin API.
The Maxima plugin has already survived several API changes, sometimes Andrey made adjustments even to third party plugins immediately, sometimes major re-work is required and update delays result from that. Unfortunately, I probably will only get up and running again with Visual Studio in summer. There is quite a todo list for the maxima plugin.
Maxima has it's own mechanism for suppressing evaluation/simplification, the so called "noun" property (inactive expression). I filed support for this in the plugin as request SS-3478
#265 Опубликовано: 13.03.2019 11:08:19
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi Martin. I see the request SS-3478. But I guess that this isn't related with the noun Maxima's property (x::uneval in maple, and Hold[] in Mathematica. Actually I ask some time ago something like this related with derivatives of cool prop package).
I guess that defining
bool IPluginLowLevelEvaluation.ExpressionEvaluation(Term root, Term[][] args, ref Store context, ref Term[] result)
where the difference with normal call is ref Store context, and then
termVar = SMath.Math.Computation.Preprocessing(termVar, ref context);
you can handle the case where an argument is defined, catching the variable name, and trying to determine if it is defined or not.
Actually I paste both of them from Maxima plugin source code. (But the second is commented).
frapuano 13.03.2019 11:54:00
#266 Опубликовано: 13.03.2019 23:47:19
That's interesting, Alvaro.
My understanding is that the underlying equations are IAPWS, to be tracable.
As implemented in Smath just a cluster fuck. OK, I don't need, using WASP
from Katmar. Under the hood, those functions are monkey business. I say that
because I coded those animals from personal transmission from Bernhard S.
I coded in VB. ALL OK, coded nearly all in Mathcad OK.
About your point of getting the derivative in Smath: not possible.
Not possible unless CoolProp re-coded from A ...Z.
In Smath CoolProp, you just get the interpolated value.
Most probably, those properties are respective data sets, interpolated.
IAPWS are a soup of polynomials. Correctly implemented, you will have
them on plot and derivatives.
I believe this package is the one from Valery at the time of his
web Mathcad calculator.
If interested, can check if still on my MCD 11.
I have most of IAPWS in Smath otherwise approximated, hyper accurate !
Cheers Alvaro ... Jean
PS: WASP from Katmar is not freeware but you have unlimited sessions
of 3 minutes [originally it was 10 minutes].
#267 Опубликовано: 15.03.2019 02:32:48
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi. There are some issue here:
maxima_laplace.sm (5 КиБ) скачан 93 раз(а).
Martin Kraska 15.03.2019 06:41:00
#268 Опубликовано: 15.03.2019 06:40:13
The problem seems to be the pre-mature execution of at() on SMath side. You see that if you switch off the Custom Functions plugin, then the answer is correctly displayed. Thus it isn't a translation issue. It would be desirable to keep the unevaluated response at least if optimization is set to "none".
I need to see if the Maxima plugin can do anything about it or even is the culprit.
Thank you for pointing this out. Filed as SS-4597.
Alvaro Diaz Falconi 15.03.2019 07:03:00
#269 Опубликовано: 15.03.2019 07:20:07
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi Martin. Thanks. Here, exp instead e^ seems to avoid this issue.
Implementation of the Laplace method solving a system of odes with Maxima laplace and ilt transforms, and it's comparative with numerical solution.
Laplace_Maxima.sm (55 КиБ) скачан 92 раз(а).
Laplace_Maxima.pdf (128 КиБ) скачан 109 раз(а).
Martin Kraska 15.03.2019 11:17:00
#270 Опубликовано: 15.03.2019 09:45:21
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Same as before, but with a system without a close form for the inverse laplace.
Laplace_Maxima2.sm (56 КиБ) скачан 100 раз(а).
Laplace_Maxima2.pdf (160 КиБ) скачан 88 раз(а).
#271 Опубликовано: 15.03.2019 09:49:57
Here, exp(x) instead e^ seems to avoid this issue.
As I mentioned this to Reg few days ago, then spot checked in Smath.
No difference was observed on the 15 D results. In Mathcad, yes e^
is less accurate than exp(x) that runs the Win built-in 21 D of which
the kernel retains 17 D and displays 15 by convention.
In other words, Maxima does not recognize e^ as the scalar exp(x).
#272 Опубликовано: 15.03.2019 11:16:25
Confirmed. Thank you, filed as SS-4598
#273 Опубликовано: 15.03.2019 11:19:34
Remember Alvaro, we had some exchange on that Mathsoft Collaboratory.
ODE_Laplace Read First.sm (27 КиБ) скачан 102 раз(а).
ODE_Laplace 1rst [Type 1].sm (24 КиБ) скачан 100 раз(а).
ODE_Laplace 1rst [Type 2].sm (22 КиБ) скачан 92 раз(а).
ODE_Laplace 2nd [Type 3].sm (33 КиБ) скачан 89 раз(а).
Created SS 5346 ... OK SS 6179
#274 Опубликовано: 15.03.2019 15:46:12
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi Jean.
I remember that.
#275 Опубликовано: 16.03.2019 18:22:37
Hi Jean.
I remember that.
Try that one with the forcing q(t):= t^0.5 and q(t):= ln(t)
ln(t) expands in term of Ei(,) exponential integral.
How is Maxima will react ?
ODE_Laplace 2nd [Type 3 Dirac Integral].sm (27 КиБ) скачан 89 раз(а).
#276 Опубликовано: 16.03.2019 20:35:25
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi Jean. Maxima can't find a close symbolic solution, only find the laplace transform. But this example shows how powerful is the Oscar' routine for inverting numerically laplace transforms. RKFixed and RKAdapt fails and, as you point, only the uni specialized solver dn_GearsBDF seems to solve the equation.
Laplace_Maxima6.pdf (94 КиБ) скачан 97 раз(а).
Laplace_Maxima6.sm (64 КиБ) скачан 89 раз(а).
#277 Опубликовано: 16.03.2019 23:49:28
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi. This is my attemp to solve a linear equation with polynomial coefficients by laplace method with Maxima. Even don't works, give a solution very close to the numerical RK solver, but I can't see what I'm doing wrong. Any help is welcomed.
Laplace_Maxima5.sm (99 КиБ) скачан 107 раз(а).
#278 Опубликовано: 18.03.2019 15:41:27
Can't help Alvaro.
I don't have Maxima. Just posted last minute Oscar InvLaplace.
Don't forget Frobenius for some of those kind variable coefficients.
Works fine Smath, with coefficients helper solve.
Buenos dias Amigo !
#279 Опубликовано: 24.03.2020 10:48:21
netsonicyxf
netsonicyxf
2 сообщений из 79 понравились пользователям.
I have a portable version of Smath 0.99.7251. The Maxima is under D:\Program Files\Math Tools\SMath Studio\extensions\plugins\44011c1e-5d0d-4533-8e68-e32b5badce41\1.98.7100.23756\
I put the above path into insert->settings, but it show "Cannot find maxima.bat"
#280 Опубликовано: 24.03.2020 10:52:54
Did you install Maxima? If not, follow the link in my signature and see the instructions for installing and configuring Maxima. The plugin just provides the interface.
