Maxima Plugin
Maxima Plugin - Сообщения
#241 Опубликовано: 08.09.2018 11:58:06
Extension manager conflicts should be resolved by now.
#242 Опубликовано: 13.09.2018 15:13:08
andrea993
andrea993
2 сообщений из 12 понравились пользователям.
We really need a linux port
#243 Опубликовано: 13.09.2018 16:00:34
I agree. Maybe, just an adjustment of the command line for establishing the socket connection is required. Under Windows I use
maxima-installation-path/bin/maxima.bat -l sbcl -s
This requires
- the .net socket stuff and process control to work under mono,
- a unicode-proof lisp compiler to be installed (which accepts utf-8 socket encoding), under win the only one is steel bank common lisp (SBCL).
Also, I need to know the name of the maxima process for detection of active maxima processes via System.Diagnostics.Process.GetProcessesByName(name). This is required to identify the pid for later kill. Under windows this might be "maxima" or "lisp" or "sbcl". This has changed over the years and may be different under linux.
The plugin might work even as it is, if the maxima startup script is renamed to maxima.bat.
Any information from the linuxing SMatheers is welcome.
BTW, there is a maxima build for android as well...
EDIT: It would also help, if someone could explain me how to build and debug the plugin under Linux. Under Win, I use VS 2015 with the project as found in the SVN repository. Otherwise I need to blindly make changes under win and install and test under linux. This would be a huge drawback compared to the win-only workflow, where compiling and running SMath with the new build in the debugger is just a push of a single button...
#244 Опубликовано: 13.09.2018 16:33:05
I just did some tests on a linux mint 17.2 virtual box with smath 6654:
install maxima, copy /usr/bin/maxima to /usr/bin/maxima.bat
Insert> maxima> settings: Path to maxima: /usr/bin
Then smath crashes with the following console output. Understanding this is beyond my experience level in c#.
Показать спойлер
#245 Опубликовано: 14.09.2018 03:17:37
andrea993
andrea993
System.IO.DirectoryNotFoundException: Could not find a part of the path "/home/user/.config/SMath/extensions\plugins\44011c1e-5d0d-4533-8e68-e32b5badce41/maxima.xml".
at System.IO.FileStream..ctor (System.String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, Boolean anonymous, FileOptions options) <0x7fb8bb55d1f0 + 0x001f4> in :0
at System.IO.FileStream..ctor (System.String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options) <0x7fb8bb55cf60 + 0x0004d> in :0
at System.IO.FileStream..ctor (System.String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, Boolean useAsync) <0x7fb8bb55cf00 + 0x00051> in :0
at (wrapper remoting-invoke-with-check) System.IO.FileStream:.ctor (string,System.IO.FileMode,System.IO.FileAccess,System.IO.FileShare,int,bool)
at System.Xml.XmlWriterSettings.CreateWriter (System.String outputFileName) <0x417801b0 + 0x000af> in :0
[/SPOILER]
The path is a mix of windows and linux style: "/home/user/.config/SMath/extensions\plugins\44011c1e-5d0d-4533-8e68-e32b5badce41/maxima.xml" plugin should be use '/' instead '\'
Btw I suggest you to link maxima.bat to maxima instead of make a copy
sudo ln -s /usr/bin/maxima /usr/bin/maxima.bat
On linux an IDE similar to visual studio is "visual studio code" also by MS, you can use it with C# extension
Martin Kraska 14.09.2018 05:22:00
#246 Опубликовано: 14.09.2018 05:21:09
Thanks for the comment. Seems that fixing the path separator might be a goot starting point. There must be something like SystemPathSeparator in C#, I shall find out...
Also, I shall get a more recent linux virtual box with enough space to install VS code.
#247 Опубликовано: 14.09.2018 06:24:49
andrea993
andrea993
If you public (is it already?) the code I can also give you an hand.
If you make a new virtual machine maybe is better that you use Ubuntu to develop that is ~more standard~
#248 Опубликовано: 14.09.2018 07:14:09
Third party SMath plugins are always open source. Here is the link for the Maxima plugin.
Feel free to play around with it. I guess one of the first steps will be to make the VS sln file fit for cross platform portability.
And we will need to set up a utf-8 maxima binary under linux. Under windows this is SBCL. It is available under linux as well but on my box this requires separate compilation.
BTW, Davide has offered help with streamlining the install procedure (automated maxima installation). I guess that the BTS issue SS-3562 is the right place for further discussion and co-ordination.
Ubuntu is fine for me.
#249 Опубликовано: 17.09.2018 17:59:31
Plugin updated. Mainly cosmetic changes.
Update19.sm (328 КиБ) скачан 106 раз(а).
Arie 18.09.2018 09:09:00, Вячеслав Мезенцев 17.09.2018 18:06:00, frapuano 17.09.2018 18:50:00
#250 Опубликовано: 21.09.2018 21:55:04
Example application for Fit(), MSE() and Residuals() and efficient plotting.
Example Fit.sm (13 КиБ) скачан 102 раз(а).
Вячеслав Мезенцев 22.09.2018 02:15:00, Radovan Omorjan 22.09.2018 03:02:00, frapuano 22.09.2018 08:26:00
#251 Опубликовано: 22.09.2018 03:36:05
Thank you Martin,
I tested it briefly with a larger data set and more than one dependent variable. At a first glance it seems that it works surprisingly fast. I might have forgotten but I think there is not yet a strictly numerical procedure in SMath (available via plugin) for nonlinear fitting a quite large data set to a function with multiple dependent variables.
#252 Опубликовано: 22.09.2018 08:13:04
Alvaro Diaz Falconi
Alvaro Diaz Falconi
In the attached, the functional version of the Carlos' version of LM. For some large set of data, as Omorr ask, the main problem it's the Jacobian. There are some algorithms that don't use it. In this approach, actually it's a truly mix of numerical and symbolic manipulation for the Jacobian.
lmCarlos.sm (57 КиБ) скачан 97 раз(а).
frapuano 22.09.2018 08:26:00, Radovan Omorjan 22.09.2018 10:36:00
#253 Опубликовано: 25.02.2019 20:00:58
Severe problems since SMath build 6970. Last version tested ok is 6965.
maximaproblem.sm (4 КиБ) скачан 71 раз(а).
#254 Опубликовано: 26.02.2019 04:03:40
Confirmed, I think...
#255 Опубликовано: 26.02.2019 10:12:56
Andrey
Andrey
1 сообщений из 44 понравились пользователям.
Hello SMath-Team,
I confirmed, it confuses me too
Best regards,
Andrey
#256 Опубликовано: 06.03.2019 04:29:41
The problem remained unsolved
However, it seems that Det(),Diff(),Int(),Lim(),Sum() are working well.
#257 Опубликовано: 06.03.2019 10:27:27
Int() certainly does not work.
Why bother Maxima, unless some like that cluster fuck
#258 Опубликовано: 06.03.2019 12:35:51
2270 сообщений из 3734 понравились пользователям.
Группа: Super Administrator
Plugin updated. Please try.
frapuano 06.03.2019 17:28:00, Martin Kraska 06.03.2019 15:41:00
#259 Опубликовано: 06.03.2019 15:14:38
I think it is all right now. Thank you.
#260 Опубликовано: 06.03.2019 15:40:46
I confirm that the API issues seem to be resolved. Andrey, thank you very much, I might not have been able to fix that soon.
In the test suite (Plugin maxima test.sm in the interactive handbook) there is just a new issue with displaying svg images in the Maxima-Draw-Region and in the image region. PDF and PNG work fine though.
Best regards, Martin
